- Tue Feb 13, 2018 9:20 pm
#37680
Hi,
I am trying to get High Sierra working within a VM (VMWare) using https://forum.amd-osx.com/viewtopic.php?f=24&t=3460
However, as soon as I select "Boot macOS from HighSierraAMD" the VM crashes.
I know it is possible, since there are already VMs out there, but they run slow and have graphic glitches on my setup.
I tried different USB Ports, Virtualize Intel VT-x/EPT or AMD-V/RVI on/off, Different number of CPU Cores, Different Clover Configs,...
but this seems to be a very basic problem, since no line of code is executed (I think) ...
I am doing this for the first time, so I would appreciate any help/tip
AMD FX-6300
ASUS M5A97 R2.0
Radeon R9 200
ASUS M5A97 R2.0
Radeon R9 200
