#33815
This is the VM Download links (I will add a mirror as it uploads) (for those that bitch about mega, I allocate 500GBs of bandwidth for users to download):
You want to download VirtualBox for Windows and create a new VM using an existing VM image. Point it at the HighSierraAMD VM.
You want to uncheck Floppy Drive and EFI in the System Settings for the VM.
You want to give it as much RAM as you can spare and at least 2 processors.
Now you want to open a CMD prompt and past the following commands:
 cd "C:\Program Files\Oracle\VirtualBox\"
VBoxManage.exe modifyvm "Your Virtual Machine Name" --cpuidset 00000001 000106e5 00100800 0098e3fd bfebfbff
VBoxManage setextradata "Your Virtual Machine Name" "VBoxInternal/Devices/smc/0/Config/DeviceKey" "ourhardworkbythesewordsguardedpleasedontsteal(c)AppleComputerInc"
VBoxManage setextradata "Your Virtual Machine Name" "VBoxInternal/Devices/smc/0/Config/GetKeyFromRealSMC" 1
You may get the spinning beach ball when the GUI first loads but let it do its thing and the rest should be smooth
Once the VM boots:
Setup starts immediately on OS load, first is to select your language and click continue like so:
Next is selecting your keyboard, select your keyboard and click Continue.
Next it will ask you if you want to transfer information to your mac, just select No like so:
Next it will ask you if you want to sign in to iCloud, select No:
Next it will ask you to Agree to the Terms of Service:
Next is to setup you account, enter your information and click Continue:
Next it will ask you if you want to use Express Setup, click on Customize Settings:
Next it will ask you if you want to enable Location Services, click Continue like so:
Next it will ask you to setup your your Time Zone, click on the map where you are and click Continue:
Finally it will ask if you want to participate in Apple Analytics, uncheck them and click Continue:
Once the OS loads to the desktop you want to go to Finder from the menu and click on Finder Preferences. Once Preferences loads check the Show Hard Drives box and you'll see your hard drives appear on the right of the screen.
#33823
No way to change the resolution.....yet. I'm still working on it.
Add more memory and CPUs to the system setup
Theres no OSX tools made by virtualbox
#33827
a8-9600 (not ryzen, integrated video), worked for me, with latest virtualbox 5.2.2/win (crashed on startup with older versions)
thank you!
to change resolution -
neither
VBoxManage setextradata "VM Name" VBoxInternal2/EfiGraphicsResolution 1440×900
nor
VBoxManage setextradata "VM Name" VBoxInternal2/EfiGopMode 4
works for me as well =(
#33900
Added felipepinhos fix for VMWare Player to the first post.
Got clover booting with EFI enabled, just can't get it to load the UI and no documentation on using clover with virtualbox.
#33930
Valter Martin wrote:Hey, big thanks for the support processor Ryzen for HighSierra. :thumbup: To change the screen resolution use this VMware Tools https://drive.google.com/file/d/1PjWPWX ... sp=sharing
You talking about using VMWare tools with VirtualBox?
#33934
ok
Happy Holidays
Merry Christmas and happy new year Shanee and tha[…]
Can you help me ? What step did you take pre-insta[…]
Did you even try to run the script.. Because DSDT […]
Hello everyone. Today i tried to update my amdint[…]
AMD OS X Advertisements
