#34496
Thanks!!
- I attached the VMWare Tools I was talking about.
- Also, When I run Cinebench in the virtual machine for the CPU I get a detriment in performance compared to Windows that are similar to a virtual machine running on Intel, circa 7/8%
But the OpenGL test within the AMD virtual machine fails while in the intel machine it doesn't (both PC (AMD/Intel) running with the same graphic card installed).
Is this because I'm using this alternative VMWare tools or OpenGL is meant to not work with AMD machines?
Thanks.
#34497
Is probably the modified AMD kernel thats causing the issue, thank for the VMWare tools! :thumbup:
#34498
Too bad...because the AMD virtual machine feels a bit slow processing graphical loads, even the most elementary ones.
Is there a chance that will be working int he future?
You're welcome, hope you can use them for something useful. :thumbup:
#34499
There's hope as shaneee works on his high sierra kernel
zzmadd liked this
#34504
Was reading about VirtualBox at page 6 of this thread...
Does it run without graphical glitches?
Does it run better?
Can you resize it?
Can it run on the same virtual disk or have I to create an entirely new machine?
Thanks a lot!!
#34505
Runs about the same, no graphic glitches, never figured out how to resize it. VirtualBox doesn't make additions for mac os.
#34507
Thanks, I try Virtual Box too.
Can I use the current disk created in VMWare?
Also, I added the flag you suggested to the org.chameleon.boot.plist file and I get the apple logo appearing sooner, but still I have to select the boot partition prior to that.
Is there a way to immediately boot to the OS partition?
#34509
Yes you can use the VMDK with VBox, I'll look to see if there's another option for enoch
zzmadd wrote:Thanks, I try Virtual Box too.
Try adding the Kernel Flag
"Quiet Boot"=Yes
zzmadd liked this
#34515
Where should I add it? Which file? Same as before?
#34516
Same as before
  • 1
  • 5
  • 6
  • 7
  • 8
  • 9
  • 14
Hey, I gived up last time with that setup but now […]
Thank You! This method definitely makes docker us[…]
This post ^ 100% working. Thank you mate, I final[…]
How can i do upgrade from highsierra 10.13.3 to 10[…]
AMD OS X Advertisements
