#32907
This works with VMware Player 14, a free download from VMware, you can get it here:
https://my.vmware.com/en/web/vmware/free#desktop_end_user_computing/vmware_workstation_player/14_0
Download Links
   VMDK https://drive.google.com/file/d/1vffD6q_fr-AAUYQ_DX3DLR-aLCnMsZkg/view?usp=sharing
The new VMWare tools from a good poster zzmadd is attached to the bottom of this post:
You need to enable root to run the vmware utility, here's how:
https://support.apple.com/en-us/HT204012
Then you need to add the following to your VMs VMX file at the bottom:
 svga.minVRAMSize = 8388608
Now you need to change the resolution and here's how:
Open Terminal, then change directory by entering cd "/Library/Application Support/VMware Tools/", include the ""s because the directory names have spaces in them.
Now you need to enter SU and then enter the password you set for root.
Once you do that you enter:  ./vmware-resolutionSet 1920 1080.
The 1920 is the height and the 1080 is the width.  Set it to what you need.
You will not want to go full screen, in my testing full screen resets the resolution back to default.
Now shutdown and restart the VM to test your new resolution.
Shaneee, Bloo, fsagent and 1 others liked this
by: Chengzhir
#33227
Hi, I installed on my virtual machine failed.After creating a virtual machine,it does not open normally.(The above is Google translation, I do not understand English)
Configuration:
CPU:ryzen5 1600x
GPU:GTX 1080
by: Norton287
#33237
Did you configure it according to the post for the VM?
by: DragonSky
#33248
Same here. I've followed the instructions carefully but VMWare keeps restarting and never goes to the setup screen. I have an Ryzen 3 1300X if that helps.
by: Norton287
#33252
Where does it restart at can you give me an example to troubleshoot.
Are you using VMWare Player 12 or VMWorkstation? Did you upgrade the hardware on the VM if you're using Workstation?
by: skazord
#33417
Doesn't work for me.
2017-11-28T00:40:10.803Z| vcpu-0| I125: AHCI: Tried to enable/disable IO space.
2017-11-28T00:40:10.803Z| vcpu-0| I125: AHCI-VMM:HBA reset issued on sata0.
2017-11-28T00:40:10.816Z| vcpu-1| I125: CPU reset: soft (mode 2)
2017-11-28T00:40:10.835Z| vcpu-0| I125: BIOS-UUID is 56 4d d5 8b e2 15 82 07-6c ae f5 70 d8 28 eb 4e
2017-11-28T00:40:11.360Z| vcpu-0| I125: Triple fault.
2017-11-28T00:40:11.360Z| vcpu-0| I125: MsgHint: msg.monitorEvent.tripleFault
2017-11-28T00:40:11.360Z| vcpu-0| I125+ A fault has occurred causing a virtual CPU to enter the shutdown state. If this fault had occurred outside of a virtual machine, it would have caused the physical machine to restart. The shutdown state can be reached by incorrectly configuring the virtual machine, a bug in the guest operating system, or a problem in VMware Player.---------------------------------------
2017-11-28T00:40:12.341Z| vmx| I125: Stopping VCPU threads...
2017-11-28T00:40:12.341Z| vcpu-0| I125: CPU reset: hard (mode 2)
2017-11-28T00:40:12.342Z| vcpu-1| I125: CPU reset: hard (mode 2)
2017-11-28T00:40:13.343Z| svga| I125: SVGA thread is exiting
Ryzen 5 1600
Gigabyte AB350 Gaming 3
R9 390
Using VMWare Player 12
Followed the guide provided line by line, even used the exact same parameters (RAM, CPUs, etc). It's worth noting that this is the exact same error I got with the 10.12.6 versions floating around.
Really bummed that this doesn't work, I needed an updated Xcode to work on my main PC, and will be instead forced to use it on a 5 year old laptop with little memory that struggles to emulate the phone :/ Thanks for the effort though, if you need more info, I can post the full log.
by: petrigno
#33427
Hi, please split the file into several parts because it's the 6th time i unload it and I always get some decompression errors at different points of the file if you divide it if anything else we should just download the corrupt part, thank you
by: Norton287
#33432
I'm trying a fix for ryzen users, will give an update tomorrow
I need someone to download VMware Player 14 and install the VM but when asked to upgrade the VM choose Yes and then try to run.
skazord liked this
by: skazord
#33503
Norton287 wrote:I'm trying a fix for ryzen users, will give an update tomorrow
I'm not home right now, but I'll try later tonight and give feedback.
by: Norton287
#33504
Ok thanks very much
  • 1
  • 2
  • 3
  • 4
  • 5
  • 14
Hey, I gived up last time with that setup but now […]
Thank You! This method definitely makes docker us[…]
This post ^ 100% working. Thank you mate, I final[…]
How can i do upgrade from highsierra 10.13.3 to 10[…]
AMD OS X Advertisements
