Yeah that's right, we will help with Windows too.
by: ho dor
#45473
Hello OGS, I wanted to switch to the Mac OS on my custom pc and have no idea if my parts are compatible with the necessary drivers for a fully functional MAC OS version. Thanks
This is my hardware:
- AMD Ryzen 2400G with Radeon Vega Graphics. )CPU)
- ASUS ROG Strix Radeon RX 560 16CU 4GB Gaming GDDR5 DP HDMI DVI AMD Graphics Card
- HyperX FURY 2666MHz DDR4 Non-ECC CL15 DIMM 8GB DDR4 2666 MT/s (PC4-21300)
- 250 GB PNY SSD
- DEEPCOOL GAMMAXX 400 CPU Air Cooler with 4 Heatpipes, 120mm PWM Fan
- ASUS B450 Micro ATX Gaming Motherboard Gen2 (Prime B450M-A/CSM)
I wanted to know if it would be compatible, and if you could link me to any drivers required that would be helpful appreciate da help greatly.
Stay Pimpin,
by: AK23
#47176
as far as I know, these parts are fully compatible just the GPU can cause some problems(not sure) else everything looks perfect
@qtwhl Absolutely! I find the devs did an amazing […]
Hello, My Friends! I'm a Brazilian user, my knowl[…]
I followed the tutorial here: https://vanilla.amd[…]
Will my config work as a ryzentossh?
I have never even built a PC and i really wanna ma[…]
