Important News and Announcements are found here.
#42757
installshield wrote:
Thu Sep 20, 2018 12:24 am
Good morning gentlemen
After updating the system with this kernel, will it display natively the data of my Rysen 7 1700x in [About this MAC]? Or are you editing this data by force? Thank you so much,
David - Brazil / São Paulo
If you mean the CPU name in About this Mac then look here,
viewtopic.php?f=24&t=1495
by: decka
#42832
run usb installer, then choose terminal
run This command
kextcache -i /volumes/nameyourDrive
then
kextcache -u /volumes/nameyourDrive
restart and boot from your drive again
by: mido_fedo
#42883
this kernel solve some problem to me like now clock set right and some videos not working with voice now working good
but still one problem i can't solve it my cpu FX4100 not enter idle mode ever and always run with maximum frequency how can i solve this problem?
by: Godeek
#44243
Shaneee wrote:
Sun Jul 22, 2018 9:02 pm
While waiting on updated xnu sources a couple things have been resolved in the kernel source. Massive thanks to AlGrey for the help.
Kernel Changes:
  • Ryzen bus frequency detection fixed. This fixes the audio issues on APUs.
  • L3 Cache detection fixed for Ryzen.
  • Fix FX L3
  • Fix Ryzen Core/Thread Count
To update the kernel on your current system follow these steps.
Navigate in Finder to /System/Library/Kernels
Rename kernel to kernel.backup
Copy new kernel in place.
Now open Terminal and run this command.
sudo kextcache -i / && sudo kextcache -u /
Download:
https://github.com/Shaneee92/AMD-High-Sierra-XNU/releases/download/1.1.1/AMD.10.13.3.Kernel.zip
After updating the kernel, I get a black screen….
I have a Nvidia GeForce GT710...
by: TN9595
#44348
I think he claimed that that very kernel files doesn't work with 10.13.6 (page 1)
by: Brainfcker
#46221
Any news about Hardware Virtualization/Hyper-V support in kernel?
Well, of course there is alternatives to run android emulator/docker or something else but it's not so handy in some ways...
Does anyone know some research info about how to make to work AMD-V on hackintosh?
I wounder because now I'm working as RN-developer and I planning to upgrade my PC. But I really don't want to build it on intel :(
  • 1
  • 4
  • 5
  • 6
  • 7
  • 8
How to force install 10.14.1?
The Vanilla patch made updating so easy. No more r[…]
The guide worked perfectly for me. Thanks. Specs[…]
try this https://www.youtube.com/watch?v=Y9I-OINW[…]
I have same cpu, any tips appreciated. Firm inte[…]
