Important News and Announcements are found here.
by: tikizondo94
#42353
Attached is a crash log. Crashing when trying to use -enableleaf with latest test kernel. Running 10.13.5. Ryzen 1700.
by: Bal
#42377
AlGrey wrote:@collector43, 10.13.4 and 10.13.5 need kexts rolled back. Better to wait on updated kernel.
Which Kexts need rollback? To which version? I want to try to upgrade to 10.13.5 because it should have better support for my Vega 64. At 13.3 Final Cut Pro X crashes, when it tries to stabilize video.
by: AlGrey
#42384
Bal wrote:
Fri Aug 24, 2018 8:43 am
AppleRTC.kext, AppleSMC.kext, AppleSMCRTC.kext, AppleACPIPlatform.kext, AppleAHCIPort.kext, IOAHCIFamily.kext, IOATAFamily.kext, IONetworkingFamily.kext and IOUSBHostFamily.kext need a rollback from 10.13.3
by: Bal
#42390
AlGrey wrote:AppleRTC.kext, AppleSMC.kext, AppleSMCRTC.kext, AppleACPIPlatform.kext, AppleAHCIPort.kext, IOAHCIFamily.kext, IOATAFamily.kext, IONetworkingFamily.kext and IOUSBHostFamily.kext need a rollback from 10.13.3
:) Thank you a lot! It finally works on my test drive.
by: trivium1992
#42391
How would I go about making a HighSierra vanilla drive with the updated kernel? Right now I'm using the sudo command in terminal to restore the 10.13.5 image to usb then what? or I'm I doing it the wrong way? I'm wanting to test on my system... I need to know the right procedure so if someone could message me that would be great! :thumbup:
by: Bal
#42412
actually apfs drives are not working without apfs.kext rollback. With that it boots up but gets stuck from time to time and shows errors with apfs in console. i guess there is no fix for this without a new kernel. Or do you know a way to fix this @ElGray or @Shaneee ?
by: installshield
#42754
Good morning gentlemen
After updating the system with this kernel, will it display natively the data of my Rysen 7 1700x in [About this MAC]? Or are you editing this data by force? Thank you so much,
David - Brazil / São Paulo
  • 1
  • 4
  • 5
  • 6
  • 7
  • 8
muy buenas recien instale mac os highy sierra en […]
Black Screen before installation
I had the same issue. Try unplugging and plugging […]
I too have ATI 7610m and the zip file is corrupt[…]
Ryzen 5 with Nvidia 1060
Hi @Johnata , Many thanks for reply. Sorry, toda[…]
