Important News and Announcements are found here.
by: rlin
#42091
Hi shaneee, I read above you said new kernel works for 10.13.5, but we may need to wait for the new combo package from Apple? Does updating to 10.13.5 currently work? I seem to running into the "service only ran for 0 seconds. Pushing respawn out by 10 seconds" problem, and I have replaced the kernel on my PC.
by: AlGrey
#42094
@rlin, if you read the last three posts you won't even ask the question ...
by: LEXXX
#42182
tikizondo94 wrote:
hoeman wrote:
Tue Jul 31, 2018 9:28 am
tikizondo94 wrote:
Mon Jul 30, 2018 7:47 pm
@Shaneee Your latest Ryzen kernel is killing it! Updated to 10.13.5 without a stutter. Some of the best performance my machine has had on OSX to date. Even Sleep is working properly! Amazing! Again, Thank you for all your hard work. Its much appreciated!
Could you detail the steps to update to 10.13.5? I installed using highsierrav3 unofficial and I'm using 10.13.3 but I'm keen to update to 10.13.5 with the new kernel. Could you teach me?
Sure. Update to the Shaneees latest kernel first. Then i followed the instructions posted here ...
viewtopic.php?f=52&t=4541
gonna try this shortly as I've been stuck on 13.3 thanks for posting gonna follow that tutorial
#42191
Kernel updated now to fix Ryzen core / thread count issue. Thanks to Algrey.
https://github.com/Shaneee92/AMD-High-Sierra-XNU/releases/download/1.1.0/AMD.10.13.3.Kernel.zip
Jimmy1232 liked this
by: myname71
#42193
Does it fit also for Fx?
by: armanip
#42200
Hey so I just used the new kernel for ryzen core/ thread issue but now when I run my music production software the video lag is unbearable :( this was the only change I have made. Does the cpu optimization on the discord help with this?
by: AlGrey
#42201
@armanip, are you using the webdrivers ? can you use cinebench to compare with previous kernel ?
by: armanip
#42202
this was after the kernel update:
https://browser.geekbench.com/v4/cpu/9353040
This was before:
https://browser.geekbench.com/v4/cpu/9353624
both side by side:
https://browser.geekbench.com/v4/cpu/co ... ne=9353624
all I did to install was download the kernel and use terminal like stated in the first page of this thread
could it be my GPU (listed in my sig) ? It only happens when I use the music production software which is kinda irritating cause I need fast visual feedback. I don't do any gaming which is why I went with that GPU and when I looked on the website for the software it has no minimum system requirements with GPU since its more CPU intensive
by: tikizondo94
#42207
armanip wrote:
Thu Aug 09, 2018 9:37 pm
Im noticing the same issue when running videos in vlc. Just noticed it
by: myname71
#42208
I Haven't wait for Shanee answer after my post above, I installed his latest kernel release, but it doesn't work.
I obtained this error:
<a href="http://it.tinypic.com?ref=16h9761" target="_blank"><img src="http://i65.tinypic.com/16h9761.jpg" border="0" alt="Image and video hosting by TinyPic">Image</a>
So I booted osx from a usbkey, then I restored the privious one release.
I hope that this can help Shanee or somebody else
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
Thank you very much for this guide. Everything is[…]
:thumbup: Post Merged :clap: Post Merged b[…]
On the off chance that
Trialix I utilized this machine of development, an[…]
Just wondering if the parts I've chosen will work […]
