Important News and Announcements are found here.
#39413
And I'm up and running :thumbup:
Dark Diver, AlGrey, Enzotron and 1 others liked this
by: myname71
#39414
:thumbup: :thumbup: :thumbup: :thumbup:
by: serialkillazzs
#39790
if you can get a hand on a rx480/ 580 to test kernal/build even better. Had a knightmare with previous gigabyte ab350n wifi board and rx580, booting older drives from sata on board cluster was a knightmare. rocking a newer asus rog strix b350i board at minute. gigabyte failed, sent back for repair and said was fixed but wasnt. so beware with gigashite as i call them now
my build to test soon: asus b350i mini itx, ryzen 1800x, rx580, toshiba ocz m.2 512gb, corsair 550 psu
#39959
serialkillazzs wrote:if you can get a hand on a rx480/ 580 to test kernal/build even better. Had a knightmare with previous gigabyte ab350n wifi board and rx580, booting older drives from sata on board cluster was a knightmare. rocking a newer asus rog strix b350i board at minute. gigabyte failed, sent back for repair and said was fixed but wasnt. so beware with gigashite as i call them now
I've got an ROG Strix RX 560 now :thumbup: Running just fine.
Egress liked this
by: serialkillazzs
#41321
What build and guide did you use to get rx560 to inject/fire
i have a sapphire radeon rx580 8gb
new micro itx rog strix board with 2 nvme, going to pick up a small samsung pro evo for second slot and boot from it. hoping to get dual boot on windows 10 enterprise
is the kernal stable on your rx560? any issues?
maybe even try triple boot with new android 8.0 rc1 android x86 release if it can fire monitor at 4k :crazy:
#41322
Just needs DeInit checked in Clover to enable the GPU.
by: AdamJames
#41383
I need to upgrade me CPU when I get the chance, this 4300 isn't gonna cut it lmao
but great news you'll be able to work with Ryzen team!
by: Pospik2705
#44725
I have aswell problem with shitbite .. im going to buy ASUS ROG STRIX B350i itx
by: TimurLivanov
#44878
Hello buddy, help please, I have ryzen 1700 + rx590 I can not install Hackintosh, what should I do? I get a black screen (((
Motherboard - ASUS STRIX B350-F GAMING
The processor - AMD Ryzen 7 1700 3.0GHz,
RAM - Kingston HyperX Predator 16 GB 3000 MHz
Video Card - AMD Radeon RX 590 Red Devil 8 GB
SSD - Plextor S3C 128 GB
Power Supply - Cougar STE 600W
I can not install Hackintosh(((((
just had a popup stating that update 10.13.6 is re[…]
VMware and Mojave?
HI is it possible to run macOS mojave in VMware on[…]
Please Help
In your clover config.plist you'll want to add a[…]
First of all I wanted to say thank you for the gu[…]
