Important News and Announcements are found here.
#39280
So guys thanks to a very generous friend online I'll soon be able to work on the Ryzen part of the kernel and test it my self in a hope to make some important improvements. Ordered is a Ryzen 5 2400G with a Gigabyte GA-AB350-Gaming 3 motherboard.
This will enable me to collect the info I need and test on the fly any kernel adjustments once I've got it up and running.
So expect to see some kernel improvements hopefully once I'm fired up and on the go :thumbup:
AlGrey, sect0r5, Enzotron and 4 others liked this
by: AlGrey
#39281
Great news :thumbup:
#39302
First part of the order has arrived :P I'll need to send the board off to Gigabyte once I get it to have the BIOS updated to support the new CPU though.
RagingDemon, Lin12345 liked this
by: Enzotron
#39304
Shaneee wrote:
Fri Apr 06, 2018 10:44 am
I wonder if it would it be possible perhaps to temporarily insert a compatible GPU from your older rig just so that you can perform the Bios Upgrade yourself from within the BIOS.. with a prepared USB just wondering... could be worth a try...
I assume that perhaps the onboard CPU graphics may not be recognised by the Bios, so it may default itself to a GPU in the PCI card slot. it doesn't even have to be a Mac compatible GPU to get to see the Bios...
The newer bioses can even connect to the net to download the Bios update, so preparing a Bios update USB may not even be required... just an ethernet cable if your lucky..
just checked the Manual... no in-bios net update of bios but page 20 of the User Manual for the mother board says:
To access the BIOS Setup program, press the <Delete> key during the POST when the power is turned on. To upgrade the BIOS, use either the GIGABYTE Q-Flash or @BIOS utility.
• Q-Flash allows the user to quickly and easily upgrade or back up BIOS without entering the operating system.
so if you can get as far as a visible post, getting Q-Flash up before any OS comes into the equation, you may have yourself an upgraded bios using the file downloaded onto some usb media
#39305
The CPU it's self isn't supported in the BIOS so it won't even post unfortunately.
by: Devagya_007
#39307
you should have purchased ryzen 5 1600, totally worth spending 50 more bucks. )
by: AlGrey
#39330
@Shaneee, you can also request your "boot kit". Idk which option is faster :P
https://support.amd.com/en-us/kb-articles/Pages/2Gen-Ryzen-AM4-System-Bootup.aspx
https://support.amd.com/en-us/warranty/rma
#39331
@AlGrey, Requested it today as the CPU has arrived :thumbup:
tikizondo94 liked this
by: RagingDemon
#39363
Woo hoo! Thank Shaneee in advance for all the great work you put in and also in your own time!
:thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
just had a popup stating that update 10.13.6 is re[…]
VMware and Mojave?
HI is it possible to run macOS mojave in VMware on[…]
Please Help
In your clover config.plist you'll want to add a[…]
First of all I wanted to say thank you for the gu[…]
