Important News and Announcements are found here.
#16320
The forum will now show the Browser and OS you've made your topic/reply from. All older posts will show as a question mark but that can't be changed I'm afraid. All new post will be shown :thumbup:
Sundhar88, Ackados, NickS and 1 others liked this
by: Jordi
#23249
shanee again forum.amd-osx.com comment adblock and i cant read other peoples messages. shanee when i tols you forum.amd-osx.com dont have ssl and you shanee comment me that is expensive and ssl in not imoortant, now shanee i see you you put ssl on forum.amd-osx.com from where you get ssl. i want too ssl, but for me is much expensive.
#23280
@Jordi, The Adblock message only shows if an Adblocker is present. Add the domain to your whitelist and it'll be gone. As for the SSL, I've added the SSL option bundled with CloudFlare which runs on the backend of the server.
#23281
by: Jordi
#23345
what is adblocker. i only have chrome. this false protection is false. shanee how are you. take care.
just had a popup stating that update 10.13.6 is re[…]
VMware and Mojave?
HI is it possible to run macOS mojave in VMware on[…]
Please Help
In your clover config.plist you'll want to add a[…]
First of all I wanted to say thank you for the gu[…]
