#46098
Ive successfully downloaded, restored and installed the AMD Os X Sierra. And then went back and did the Post command and it gave me the prompt "you should now be able to boot from your hard drive" and when i reset and try booting from the HDD, my computer just resets an brings me back to my bios options. Any clue what could be causing this?
Hi guys. I'm new here and new in this hackintoshin[…]
Help make USB Installer
Yes, ViciBox v.6 and later 6/7/8 can be successful[…]
Use only the internal GPU of the CPU because you c[…]
I understand what you tell me though I wanted to a[…]
