by: Skellgon
#45499
Hi everyone,
I just installed Mac OS Sierra with the 5.2 Image on my AMD machine.
It was installed without any problem - I even performed the post-installation steps without any issue.
After that I tried to boot from my SSD - the Mac-Welcome Screen appeared.
I confirmed the language and keyboard layout and then it asked me about my ethernet-connection.
When I confirm the DHCP-Setting it seems to crash with the message you can see in the attachement.
I tried it several times and every single time it crashes on the same step.
What am I doing wrong?
My specs:
AMD FX-4300 4x 3.8 GHz
NVIDIA GT 1030 GPU
8 GB (2x4GB) Ram
240 GB Samsung Evo 840 SSD
just had a popup stating that update 10.13.6 is re[…]
VMware and Mojave?
HI is it possible to run macOS mojave in VMware on[…]
Please Help
In your clover config.plist you'll want to add a[…]
First of all I wanted to say thank you for the gu[…]
