by: MikaMi
#29626
Hello :D
I can't get Ethernet to work with the GIGABYTE 970A-UD3P mainboard. I tried all Multibeast kexts for Realtek and the AppleRTL8169Ethernet kext and a few other things I read in the forum. Bit nothing worked so far.
Everything else than Ethernet is working fine (Sound, USB, Graphics, Booting ....)
Does anyone have the same problem or have a fix for it?
#29627
First multibeast is an Intel utility don't use it. I'll look up your motherboard and get you a kext
Install this kext with kext utility, just unzip and drop the kext on kext utility to install.
MikaMi liked this
by: MikaMi
#29656
Norton287 wrote:
Sat Oct 14, 2017 9:26 pm
Okay I did not know that. It worked with the USB and Audio drivers, but they aren't Intel so I think thats the reason for the success.
I removed the old ethernet kext I tried and tried this one. It worked :clap:
Thank you, you helped a lot :thumbup:
by: Norton287
#29659
No Problem. :thumbup:
by: LeYACK
#43873
I find this post for the same reason I can not install the given kext so on to activate my ethernet.
same motherboard gigabyte 970a ud3
a little help? thank you
Make sure that the cpu clock frequency is correctl[…]
Hi, i have a problem, when trying to install Sierr[…]
RADEON HD 5450 GRAPHICS ISSUES
:wtf: I've recently installed Mac OS High Sierra […]
@AlGrey , Done! Actually attached are two IOREG […]
AMD OS X Advertisements
