#50149
So I just installed macOS sierra AMD 5.2 successfully and I Installed the NVIDIA WEB drivers as well as the clover bootloader. I restarted the system and ended up getting stuck at "PCI Configuration Begin" and I added a command to my config.plist that fixed that. But now whenever I try to boot into my disk I get almost all the way through but then the last thing I see is "considerRebuildofPrelinkedKernel rebuild prebuild has expired" and I can't figure out how to bypass it. My system is an AMD FX 4100 CPU, an ASUS NVIDIA GTX 650 graphics card with 2gb of VRAM, and I have an ASUS motherboard. my boot loader config.plist commands are the following "-f -no_compat_check -dart=0 -npci=0x2000 -v -nvda_drv=1.
Have you installed NullCPUPowerManagement.kext? In[…]
I have the same hardware with gtx 1060 graphics. A[…]
Not microphone...micro ATX...I had ASRock X570 Pro[…]
Specs: CPU: AMD Ryzen 9 3900x Motherboard: Asus […]
