#44845
Enoch loads fine but i can't boot clover at all from my usb unless all my hard drives are unplugged from the inside of my pc
I have tried everything and am booting from clover legacy
if one or more hard drives are plugged in, when i try boot to my usb, it shows a flashing underscore for around 20 seconds then goes to a smaller, solid underscore in the top left which it then hangs at.
I dont know what else i can do but ask on the forums.
thanks in advance for any help
#45159
felmadson wrote:Enoch loads fine but i can't boot clover at all from my usb unless all my hard drives are unplugged from the inside of my pc
I have the same MB; connect your USB on 2.0 , and just wait; this MB is slow! give to him at leas 5 minutos to load bootloader; are you using MacOs to make the clover?
Hi man in the suit, I would try using the HDD from[…]
I think I read somewhere that a guy having the sam[…]
Tp Link Tl-wn823n is USB and works out of the box
Problem at installation reboot
Looks like some files are missing from the install[…]
