• SierraAMD 5.2 Successfull install amd ryzen cpu
#38747 by Jprabu
Thu Mar 08, 2018 12:50 pm
My Cpu spec Ryzen 3 2200g processor 8gb ram 500gb hdd gt1030 graphic card
successfull install mac os
new methods of post install script every one to easy to run post script
follew the spets
1. install paragon hfs software windows
2. mac os install coplete open windows os
3. show the mac os install partiiton
4. Copy Kernel file post install folder replay the mac os patition install partition System/Library/Kernels/
5. Copy Kexts files post install folder to mac os patition System/Library/Extensions
6. Remove Problem Kexts files from macos partition
7. Remove old PrelinkedKernel and copy amd PrelinkedKernel file /System/Library/PrelinkedKernels
