by: veleay
#37765
Hello guys,
I've successfully installed SierraAMD_V5 on my Gigabyte 990FXA UD3 / FX 8320 system. Everything is working fine except for my Focusrite Scarlett Solo. The point is that the system doesn't recognise it as audio device, it's only listed as USB device when I use it on a USB2 port. On a USB3 Port it does function properly but after like 5 minutes the Interface just crashes and doesn't work again until I reboot the system (this happens on Windows 7 as well). Every single USB port with every other device is working fine. I really don't know what to do anymore, I'm literally clueless...
please help me. :c
by: GeorgeBogus
#37808
Well propably the best option is to change interface.
Its like 10th topic about this, I have the same problem and no one can help me...
I think about giving up with Hackintosh, cuz I cant install High Sierra, and my interface cant work.
hp elitebook 745 g3 El Capitan
SPEC: AMD PRO A8 -8600B with AMD Radeon R6 Graphic[…]
How should I solve this problem, please help me h[…]
Hi there! Congrats!! Do you plan to use it for vi[…]
You can try this for USB, https://forum.amd-osx.co[…]
