by: Norton287
#37761
most processors have a turbo speed, not overclocked just built-in.
#37763
What kernel is in use? Bronya's seems to have issues with Bus ratio. My High Sierra one auto sets it. My guess is my Sierra kernel should too. Type the following into Terminal and paste the output here,
uname -a
by: lucasbesen
#37766
Norton287 wrote:most processors have a turbo speed, not overclocked just built-in.
How can I see this? In AMD site don't say anything. CPU-X:
Shaneee wrote:What kernel is in use? Bronya's seems to have issues with Bus ratio. My High Sierra one auto sets it. My guess is my Sierra kernel should too. Type the following into Terminal and paste the output here,
uname -a
Darwin Lucass-Mac-Pro.local 16.5.0 Darwin Kernel Version 16.5.0: пятница, 25 августа 2017 г. 13:40:14 (MSK); root:xnu-3789.51.2_amd/BUILD/obj/RELEASE_X86_64 x86_64
#37767
Ok that's Bronya's kernel. Try this. Unzip to the desktop then double click on KernelUpdate and follow prompts. Remove any busratio flags and reboot.
#37773
Does it reboot or panic? This kernel works on FX and is the one I used myself.
by: lucasbesen
#37774
I rebooted and now says it have no kernel. Put kernel in Desktop and started KernelUpdate, like u said
#37775
Use the installer and run post install again. I'll walk you through manually replacing the kernel once you're in the system again.
by: lucasbesen
#37779
Now, I can't boot even with USB. Installer don't next in language selector........
Following https://forum.amd-osx.com/viewtopic.php?[…]
@Valamyr @Marcyvee It's working on Mojave when &q[…]
hello shanee I am stuck at the first start on the […]
zederex Clearly, this is going to lengthen the[…]
