#32742
Hi!
Need a little help with installing macOS Sierra 10.12.6 App Store version on my AMD PC.
PC:
Asus Sabertooth 990FX R2.0
AMD FX-8350 Processor
2x MSI Radeon R9 280X GPU
Realtek ALC892 @ ATI SB900 - High Definition Audio Controller
16GB of RAM
I use Sierra v5.0 installer image from AMD OS X forum, made a bootable USB stick with TransMac.
Have tried different opportunities to install OS but only way is installing OS from USB in Legacy mode only. If I try to boot in UEFI, it hangs and won't go futher.
So I have installed Sierra from my USB memory in Legacy. Installing was successful, made a restart. Booted up from USB again and installed POSTInstall. After that I can't boot from my macOS HDD. Trying to boot, but everytime it will crash and PC restarts continously.
Please help.
#32743
There are other options for legacy boot, you need to start asking for help sooner.
Download v5.2 with enoch bootloader:
 https://mega.nz/#!p3ZBnbhI!qfUYdrwgWc1yZBP9fYoau2ShyXsirmw9Y_CkJeydKD4
During PostInstall it will copy an Enoch Files folder with a preconfigured Extra Folder and an Enoch Installer. After you install Enoch copy the preconfigured Extra folder to the ESP or where ever you installed enoch too.
#32784
Got it work. Thanks a lot. Now have to install right network and audio drivers. Used Multibeast, but if I install Realtek ALC892 drivers, my audio doesn't work. Same with network.
#32785
Don't use multibeast, put your hardware in your signature and I'll look up drivers for you.
For audio use: VoodooHDA and install with Kext Utility.
Put your system specs in your signature and I'll get you a network kext.
Here's your network kext, install it with kext utility:
#32787
I got your kexts one message above, install them with kext utility by dropping the unzipped kext onto the kext utility window
#47376
I have the same build, for the mob and cpu, I have issues with usb 3.0 ejecting when over used such as read and write speeds being high or stressed out. Still searching for a solution
OS Sierra\
sabertooth 990fx r.2
FX 8350
I got the same problem, look forward to fixing it […]
Hardware: Processor: AMD FX 8300 Graphics Card: […]
Can you help me? In my installation it gives still[…]
Hi everyone, Ok so I've "almost" instal[…]
