by: Norton287
#31673
Must not have installed 10.12.6 or have installed 10.12.6 and the security update. You will boot only to the installer if it makes it that far and report back.
by: choerte
#31694
Hello,
I would be glad to help out testing. Tried to install SierraAMD_V5 and V5.2 on Samsung 960 EVO NVMe, but couldn't get to the installer. Got stuck at the screen below.
I have a Threadripper and an ASRock X399 Taichi motherboard. But it's my first time trying to hackintosh, so I'd need some guidance...
by: Norton287
#31695
Check your PMs
#31701
Is this what you are using? If not have you tried it?
by: Norton287
#31705
No I’m using Rehabmans NVMe patcher to build the NVMeHacker kext, their injectable through clover.
The KextstoPatch from Pike R Alpha caused kernel panics in Ryzen cpus.
#31708
Ahh right yeah. That the one with the clover kext patch too or has he updated it since I last looked?
by: Norton287
#31709
He’s updated it to allow the NVMe kext in S/L/E to stay and he did an update for the security update as well.
Updated the build with a new way to implement the HackerNVMe Keats.
The HackerNVMe kext work like crap, but good news the Kext Edits in clover work good so far. Update 5.2 postinstall with edits for the security update.
Shaneee liked this
by: Paparazzi
#34391
Im new to message boards and new to computer building... But are you saying that it IS possible to have your boot drive be a NVME? Does it matter which manufacturer you use?
by: Norton287
#34393
Seems to work with EVO and M.2 drives. Only 5.2 works, it has the kext patches to make it go.
by: mexpat911
#36571
Is this still an issue ? I currently have a Samsung 960 Pro booting high Sierra with APFS.
I can post whatever if needed.
Sorry, but I don't know where to find/upgrade it. […]
[Posible Solution] I had the same problem, then I […]
How to install Mojave
Change to another USB port and check if your USB […]
I used High Sierra v2, v2.5 (Clover And Enoch), V3[…]
AMD OS X Advertisements
