by: lordsith82
#31144
Hello,
I have a problem with Indesign 2018 and illustrator 2018.
Is there a fix as Photoshop 2018?
Thank you.
#31538
Open Terminal and type this command :
sudo rm -rf /Applications/Adobe\ Photoshop\ CC\ 2018/Adobe\ Photoshop\ CC\ 2018.app/Contents/Required/Plug-ins/Extensions/FastCore.plugin /Applications/Adobe\ Photoshop\ CC\ 2018/Adobe\ Photoshop\ CC\ 2018.app/Contents/Required/Plug-ins/Extensions/MMXCore.plugin
by: lordsith82
#31554
This is for photoshop...
My question is for illustrator and indesign.
Thank you.
#31559
Check for the plugin still. MMXCore may still be there. It's caused many issues on AMD in the past.
by: lordsith82
#31844
nope.. INDESIGN 2018 still crash... other ideas?
by: lordsith82
#33229
Help please... :)
by: tinyj
#42333
You'll have to use an earlier version. See here: reddit.com/r/hackintosh/comments/809t8k/adobe_application_fixes
#42335
Try with this,
https://www.dropbox.com/s/gt3cbuaxt4y2njm/Adobe%20CC%20Fix.zip?dl=0
The guide worked perfectly for me. Thanks. Specs[…]
try this https://www.youtube.com/watch?v=Y9I-OINW[…]
https://fitose.com/keto-fuel/
In these days of supersizing, buffets, and large d[…]
I have same cpu, any tips appreciated. Firm inte[…]
