#26121
I am having an issue where my clock will loose a few second every minute and after a few hours the clock will be off by 5-10 minutes, and the audio has really bad stutters. From what I've been searching around it seems to be a CPU clock issue, thing is I left the CPU clock settings alone no over clocking or anything. I found one suggestion which was to enable Apple RTC in Kernel and Kext Patches in Clover but no go. Not really sure what to do at this point. Any help would be greatly be appreciated. Had to use V4 install because V5 install wouldn't even boot up.
- Gigabyte GA-AB350-Gaming 3
- Ryzen R7 1700
- Nvidia 1070
#26175
Replace the kernel with the one attached into System/Library/Kernels then run the commands below. Wait till the last one is completed before rebooting!
sudo rm -Rf /System/Library/PrelinkedKernels/prelinkedkernel
sudo kextcache -u /
butteredmuffins liked this
#26278
Shaneee wrote:Replace the kernel with the one attached into System/Library/Kernels then run the commands below. Wait till the last one is completed before rebooting!
sudo kextcache -u /
Thanks Shaneee! Unfortunately that did not work :( I tried one more time for good measure and didn't work. I made sure I isolated the sound issue by purchasing a USB sound card and that stuttering is still there along with the unsynced time. Do you think I'd have to manually set the CPU clock speeds in Clover?
So oddly enough... After overclocking my CPU it has helped the problem significantly. I'm at 3.3ghz going to try to push it to 3.5ghz and see how much that helps. This is bizarre...
#26289
butteredmuffins wrote:
Wed Aug 30, 2017 5:40 am
- Ryzen R7 1700
- Nvidia 1070
Are you still having the sync issues? If so link me a copy of your config.plist. Ill see what i can do to help..:)
#26294
tikizondo94 wrote:
Fri Sep 01, 2017 11:45 am
- Ryzen R7 1700
- Nvidia 1070
Sure am! I really appreciate you taking the time to do this, here's a link! https://drive.google.com/file/d/0B799qX ... sp=sharing
#26295
Shaneee wrote:
Thu Aug 31, 2017 8:59 am
sudo kextcache -u /
Which are the changes in that kernel? Can i use it?
#26304
Give this one a shot. I made small edits but it may help with your timer issues.
butteredmuffins, VQey liked this
#26325
Sat Sep 02, 2017 12:11 am
tikizondo94 wrote:Give this one a shot. I made small edits but it may help with your timer issues.
You are a god send :D that fixed all my major issues, thank you so much! I'm writing up a little guide with my build :)
Glad I could help:) Anytime
#26416
tikizondo94 wrote:
Fri Sep 01, 2017 7:35 pm
I'm suffering same issue.
How can I fix it?
Where did you editing in config.plist?
i'm using this installer but after verbose boot mo[…]
nice. details on the ram ? https://www.microc[…]
Inject this kext, https://files.amd-osx.com/XLNCUS[…]
Hi All, First time long time haha, CPU: R7 1700 […]
