#53987
I am primarily a Linux guy, but I wanted to see how well this hardware would run OSX
https://pcpartpicker.com/list/p8PyFG
Turns out, pretty well.
Build:
Spoiler:
  • CPU: AMD Ryzen 9 3950X
  • Motherboard: GIGABYTE X570 AORUS Master - BIOS F11
  • RAM: G.Skill Trident Z Neo 32 (4 x 16 GB) DDR4-3600
  • HDD: Installed on a Crucial M4 256GB SATA III
  • GPU: PowerColor Red Devil Radeon RX 5700 XT
  • LAN: Realtek RTL8111 ( RTL8111.kext )
  • Sound: HDMI / Motherboard ( AppleALC alcid=11)
  • Sleep: Kernel Panics
  • Monitor: 32" Acer
  • Bootloader: OpenCore-Debug 0.5.4
  • Other: iCloud/iMessage works OOB, Sidecar works. Wifi/BT doesn't work
  • Installed OS': Linux Debian 11 (Bullseye), Catalina 10.15.2 - Windows 10 Pro
EFI:
Spoiler:
├── ACPI
│   ├── DSDT.aml
│   ├── SSDT-EC.aml
│   └── SSDT-EC.dsl
├── Drivers
│   ├── ApfsDriverLoader.efi
│   ├── FwRuntimeServices.efi
│   └── VBoxHfs.efi
├── Kexts
│   ├── AppleALC.kext
│   ├── FakeSMC.kext
│   ├── Lilu.kext
│   ├── MacProMemoryNotificationDisabler.kext
│   ├── SmallTreeIntel82576.kext
│   └── WhateverGreen.kext
├── OpenCore.efi
├── Tools
└── config.plist
The only thing that tripped me up was needing to add agdpmod=pikera. Without that the screen would go black.
Boot Args: -v keepsyms=1 alcid=11 agdpmod=pikera
I got a memory warning on startup:
I believe this is because it is expecting ECC ram in a MacPro7,1. But it seems harmless. All the ram is visible.
Updates:
#53989
You can hide the memory warning with this kext, https://github.com/IOIIIO/MacProMemoryN ... r/releases
#54055
It gets everything except my Gen4 PCIe NVME drive correct. That's a 1TB Sabrent Rocket 4.0 which is my Linux boot drive (Linux is my day-to-day OS on this box).
The other drives listed as external are actually external.
I poked at it a little bit, but since I don't even mount it under OSX I didn't dig too deep. In your case, make sure you have ExternalDiskIcons set to true in your config.plist. I think there is a way to fix it in the DeviceProperties section of config.plist. My diskutil list looks like this (note the Russian disk label on disk7s1 caused by my usb stick installer for some reason deciding I wanted to do the whole install in Russian):
/dev/disk0 (external, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *1.0 TB     disk0
   1:                        EFI NO NAME                 536.9 MB   disk0s1
   2:           Linux Filesystem                         931.0 GB   disk0s2
   3:                 Linux Swap                         68.7 GB    disk0s3
/dev/disk1 (internal, physical):
   0:      GUID_partition_scheme                        *500.1 GB   disk1
   1:           Windows Recovery                         554.7 MB   disk1s1
   2:                        EFI NO NAME                 103.8 MB   disk1s2
   3:         Microsoft Reserved                         16.8 MB    disk1s3
   4:       Microsoft Basic Data                         499.4 GB   disk1s4
/dev/disk2 (internal, physical):
   0:      GUID_partition_scheme                        *240.1 GB   disk2
   1:           Linux Filesystem                         240.1 GB   disk2s1
/dev/disk3 (external, physical):
   0:      GUID_partition_scheme                        *2.5 TB     disk3
   1:           Linux Filesystem                         2.5 TB     disk3s1
/dev/disk4 (internal, physical):
   0:                                                   *6.0 TB     disk4
/dev/disk5 (external, physical):
   0:      GUID_partition_scheme                        *128.0 GB   disk5
   1:                        EFI EFI                     209.7 MB   disk5s1
   2:                  Apple_HFS SSDUSB                  127.7 GB   disk5s2
/dev/disk6 (internal, physical):
   0:      GUID_partition_scheme                        *256.1 GB   disk6
   1:                        EFI EFI                     209.7 MB   disk6s1
   2:                 Apple_APFS Container disk7         255.7 GB   disk6s2
/dev/disk7 (synthesized):
   0:      APFS Container Scheme -                      +255.7 GB   disk7
                                 Physical Store disk6s2
   1:                APFS Volume SSD — данные            13.0 GB    disk7s1
   2:                APFS Volume Preboot                 82.3 MB    disk7s2
   3:                APFS Volume Recovery                528.5 MB   disk7s3
   4:                APFS Volume VM                      1.1 MB     disk7s4
   5:                APFS Volume SSD                     10.8 GB    disk7s5
/dev/disk8 (external, physical):
   0:     FDisk_partition_scheme                        *1.5 TB     disk8
   1:               Windows_NTFS Data                    1.5 TB     disk8s1
#54391
Hi Rasmus,
I have the same setup as you and have managed to install Catalina. However everything work apart from my USB seems to disconnect from time to time, only really noticed it while backing up to an external usb 3.0 hard drive. Any chance I could get a copy of your EFI folder or .plist? I am using OC 0.5.2, every time I try to upgrade to 0.5.4 it kernal panics, don't understand why.
Thanks for any help.
Drsog
#54401
Hi Rasmus,
Is it possible you can take a look at my efi, I am struggling from past 3 days. Mojave boots and installs smoothly but I am not able to install Catalina, I have even contacted couple of people on discord as well. Here is my efi that boots perfectly for Mojave.
Whats happening with me is, as I click on Install button on recovery Installer it takes me back to Original MacOS utility window. This loops continuously. Please take a look https://drive.google.com/open?id=1NjeCH ... FRLNX1jfar
#54744
rasmus wrote: Mon Jan 27, 2020 7:30 am It gets everything except my Gen4 PCIe NVME drive correct. That's a 1TB Sabrent Rocket 4.0 which is my Linux boot drive (Linux is my day-to-day OS on this box).
   0:                                                   *6.0 TB     disk4
@rasmas,
I used the technique described in this reddit post to solve the external icon issue and can confirm it works.
https://www.reddit.com/r/hackintosh/com ... ncore_amd/
@ramsus et al,
I'd be interested in the BIOS settings people have used successfully. I cannot get my hack to post when making changes to my BIOS settings. I think it has something to do with the XMP Profile but I need to do further testing. Any insight would be appreciated.
You should not need the DSDT.aml nor the SSDT-EC.d[…]
Matx board? Sleep and wake is fine?)
Speak to XLNC on the Discord. It's a non Zen issue[…]
Help booting Mojave installer
OpenCore supports all version of 10.13, 10.14 and[…]
