#53427
Build
Motherboard: Gigabyte X570 Aorus Elite
CPU: AMD Ryzen 7 3700X
CPU Cooler: bequiet! Dark Rock 4
GPU: Sapphire Radeon RX 5700 8 GB
Memory: HyperX Black Fury 16 GB (2 x 8 GB) DDR4-2666
Storage: Samsung 970 EVO Plus 500GB NVME
Bluetooth: Asus BT400 usb dongle
Wifi: None
Case: NZXT H500
Power Supply: Cougar CMX700
Monitor: LG 27UL500
MacOS: 10.15.3 beta
OpenCore: 0.5.4
BIOS: F11
Benchmarks
Spoiler:
Bios Settings:
- Load Optimized Defaults
- XMP profile
- CSM disabled
OpenCore
Spoiler:
ACPI
- SSDT-PLUG.aml (fix CPU PM)
- SSDT-XOSI.aml (fix CPU PM)
- SSDT-SBRG.aml (fix EC)
- SSDT-NVME.aml (show SSD as internal)
- SSDT-USBX.aml (fix USB power)
- SSDT-XHC2.aml (rename XHC0 controller)
- Acpi patch for rename _OSI to XOSI
Kexts
- Lilu.kext
- WhateverGreen.kext
- VirtualSMC.kext
- AppleALC.kext (Sound ALC1200 layout 2)
- SmallTreeIntel82576.kext (Intel ethernet)
- AGPMInjector.kext (Proper video injection. Depends on video and smbios)
- AMD-USB-Map.kext (Mapping Usb ports)
- Kernel patch for proper CPU PM
SMBIOS
iMac 19,1 most stable
Drivers
- ApfsDriverLoader.efi
- HFSPlus.efi
- FwRuntimeServices.efi
Update:
- Proper USB ports mapping
- Updated to last versions of OC & kexts files
- SMBIOS changed to iMac19,1 for stability
- Updated SSDTs
Everything works except sleep. If you want to use attached EFI folder you need to generate your own SMBIOS SN.
c4orbi, Fryinfarmer, iGPU and 1 others liked this
#53464
Hi Anti,
First I want to say INFINITELY thank you for posting your EFI. I finally managed to get the system installed after being stuck for more than a week.
My system is 2700X / X570i Aorus Pro Wifi / MSI 5700 XT
Everything is working except the BT/WIFI card. My MB (Aorus x570i pro wifi) had one on board that I swapped with another confirmed supported (Broadcom BCM94352Z DW1560 6XRYC).
Could you tell me if in your EFI you added any setting/kext to disable the onboard card?
Do you have any suggestions about what could be preventing it to work properly?
#53473
enra enra wrote:Shutdown works but I had an issue also experienced by other users on this forum with the system freezing and rebooting after 5 or more minutes of inactivity.
Seems like changing the SMBIOS model to "iMac9,1" fixes it and in some cases also enable sleep/wake.
You mean iMac19,1? Yeah I'm on it, no sleep and the shutdown still doesn't work. (I have tried removing all the USB devices as well)
About the 5/10 min idle reboot, I've "fixed" with amphetamine.
enra enra liked this
Installer doesn't detect M.2 SSD
I can boot to the installer without problems, howe[…]
Of course, if all the PCIe slots are full or ina[…]
Hi all, sorry for my english ^^" I'm try to i[…]
Hi, I have same MB with 2700 CPU and RX 580 runni[…]
