#52728
Processor: AMD Threadripper 1920x
CPU cooler: be quiet! Dark Rock Pro 4
M/B: ASUS ROG X399 Zenith Extreme Alpha
Video: Asus ROG RX570 4GB / Sapphire Radeon VII
Storage: Samsung 970 Pro 1TB NVME
Memory: G.Skill TridentZ RGB Series 64GB
PSU: Seasonic Prime TX-850, 850W 80+ Titanium
Case: Phanteks Enthoo Evolv X ATX Case Tempered Glass Windows Digital RGB
Wifi/Bluetooth card: Fenvi T919 1750Mbps PCIe Desktop Wifi Card Broadcom BCM94360CD
Keyboard: Apple Magic Keyboard with Numeric Keypad - Space Gray
Trackpad: Apple Magic Trackpad 2 - Space Gray
Operating System: Apple Mac OS X 10.15.2 (19C57)
Hardware
- CPU - works, but without OS power management;
- Videocard - fully supported;
- Integrated sound - fully supported;
- Integrated Intel i211 Gigabit Ethernet - fully supported;
- Integrated Auantia AQC107 Ten gigabit Ethernet - fully supported;
- integrated Wifi/Bluetooth module - replaced with Fenvi T919 network card which have native support in MacOS thankfully for BCM94360CD chiset ;
- USB Controllers - fully supported;
Tested software - working
- Integrated software;
- FinalCutX, Motion, Compressor;
- Microsoft Office (latest from AppStore);
- GeekBench, Heaven, CineBench R20, LuxMark, Blender benchmark.
- Oracle VirtualBox;
Tested software - not working
- Parallels desktop;
- VMWare Fusion;
System features
- iCloud - works;
- System sleep - works;
- iMessage - works;
- AirDrop - works;
- Facetime - works;
- Handoff - supported;
- Instant Hotspot - supported;
Bootloader
- OpenCore Bootloader 0.5.4;
UEFI drivers
- ApfsDriverLoader.efi
- FwRuntimeServices.efi
- HFSPlus.efi
Kexts
- AGPMInjector.kext - power management for video card;
- AppleALC.kext - integrated sound card initialisation;
- Lilu.kext - common kext for most of others kexts;
- SmallTree-Intel-211-AT-PCIe-GBE.kext - integrated Gigabit ethernet initialisation;
- VirtualSMC.kext;
- SMCSuperIO.kext -VirtualSMC extension for monitoring purposes;
- WhateverGreen.kext - video card initialisation;
- USBPorts-x399ZenithAlpha.kext- USB ports map. Use this guide to map your USB according to your needs;
- NVMeFix.kext- enables power management for non-Apple NVMe storage devices.
SSDTs
- SSDT-EC - virtual device for Catalina run.
- SSDT-PLUG - Intel Power Management patch (used for video card power management patch).
- SSDT-EC-USBX - USB power parameters injection for higher currents support on USB ports (charging iPad, etc);
- SSDT-EC-IRQFIX - Fixes IRQ handling on HPET, RTC, PIC and TMR.
Utilities
- MacInfoPkg - Mac models serials generator for correct work iCloud, iMessages, etc. Use it to replace serial and board serial in OpenCore config;
- AGPM Injector - Apple Graphics Power Management Injector kext generator. Use it to generate AGPMInjector.kext for your videocard.
Version 22-01-2020
Spoiler:
Config - version 22-01-2020
+ updated OpenCore to 0.5.4 version;
+ added IRQ fix for AppleHPET - fixes problems with sleep and some stability and performance issues;
+ added NVMeFix.kext for NVMe storages power management;
+ fixed some console bugs;
+ latest versions of Whatevergreen, Lilu, AppleAlc.
Version 04-01-2020
Spoiler:
+ Resolved issue with sleep kernel panic;
+ Added support for playing protected content in TV app (shikigva=80);
+ Added USB ports map kext for proper support of USB ports and sleeping;
Version 31-12-2019
Spoiler:
+ Added SSDT-EC-USBX for correct USB power injection (iPad charging support);
- Removed some unnecessary files;
Version 13-12-2019 - Initial release
Spoiler:
- Initial release
Blender - full benchmark
Cinebench R20
Unigine heaven Benchmark 4.0
Black Magic Disk Speed Test
#52833
Saeed Haidar wrote:Hello
How did you get Auantia AQC107 to work I have the the setup but with threadripper 1950x
In my case it's supported by MacOS.
Smooth update to MacOS X 10.15.2 (19C57)
New config version 31-12-2019
Happy New Year for everyone!
#54768
Hello!
I have used you configuration and was able to install Catalina on my:
Threadripper 1920x,
Aorus Gaming 7 X399,
32GB RAM,
Radeon Vega 64 and
WIFI/BT PCI WTXUP TX-AC94360
I have only one problem - my bluetooth doesn't work although it should natively like in you Fenvi t919 (it is almost the same).
Adter installing there was no Bluetooth in "My Mac" section, but i have deleted your X399 ZenithAlpha USB Port kext and now i can see it, but there is BT adreslike 0.0.0.0 and system says that it is Ericsson, not Broadcom.
What can i do?
And what for is this USB ports kext? Do i have to make it for my X399 Aorus?
#54992
mirko.b wrote:Could you share your EFI please?
Efi you can find in config section - just open spoiler.
mecenas666 wrote:Hello!
Threadripper 1920x,
32GB RAM,
Radeon Vega 64 and
What can i do?
Problem solved. Sorry for delay with answer. ;)
I'm using the same MB For the network i'm using […]
Hi all! I'm trying to install Catalina 10.15.3 but[…]
So quick update. I swapped out the WiFi card on […]
Recently, I need to use video camera a lot to in o[…]
