#52387
Interesting how this build came about (post is still pending completion)! AMD discord has been essential in getting this build working. I decided to embark on a mini-itx build since I am tired of machines taking up unneeded space. I decided to downsize as much as possible. I settled on a B450 board since I didn't need more than a few key pieces of hardware. Here is the build:
Hardware
  • CPU: AMD Ryzen 7 1700 running @ 3.6 GHz
  • Motherboard: ASRock B450 Gaming-ITX/AC
  • RAM: G.SKILL TridentZ Series 16GB (2x8GB) - F4-3600C16D-16GTZ
  • HDD: Mushkin Pilot-E NVMe M.2 SSD 1TB
  • USB : 3.X with USB-C (10gbps)
  • GPU: SAPPHIRE Radeon RX Vega 64
  • LAN: Intel 210T (smalltree Kext)
  • LAN: Broadcom BCM94360CS2 (Natively supported)
  • BT: BRCM20702
  • Sound: USB DAC
Working:
  • GPU
  • Intel NIC
  • WiFi
  • Bluetooth
  • All USB ports
  • OpenCore boot
  • Windows 10 install
  • Sleep
Not working:
  • DRM
Pending hardware:
  • DAN case
I was a bit frustrated with the USB situation on my previous AMD board. Therefore, I decided to make a custom SSDT for this board. I was able to pull the info of my ports' exact addresses / capabilities with USBDevTree in Windows. I printed out the text report and got to work. I have attached the SSDT to the post. Every port works with the proper speed. I am currently using numerous external drives with my main driver being a 512GB Samsumg Pro 960 in an USB 10gbps capable NVM enclosure.
Let me know if you guys would be interested in anything in my system or any requests.
Spoiler:
DefinitionBlock ("SSDT-ASrock-Fatal1ty-B450-Gaming-ITXAC.aml", "SSDT", 1, "ASRock","RyzenUSB", 0x00000001)
    // Define High speed ports
    External (\_SB_.PCI0.GPP2.PTXH.RHUB.HS01, DeviceObj)
    External (\_SB_.PCI0.GPP2.PTXH.RHUB.HS06, DeviceObj)
    External (\_SB_.PCI0.GPP2.PTXH.RHUB.HS11, DeviceObj)
    External (\_SB_.PCI0.GPP2.PTXH.RHUB.HS12, DeviceObj)
    // Define Super Speed ports
    External (\_SB_.PCI0.GPP2.PTXH.RHUB.SS01, DeviceObj)
    External (\_SB_.PCI0.GPP2.PTXH.RHUB.SS02, DeviceObj)
    External (\_SB_.PCI0.GPP2.PTXH.RHUB.SS03, DeviceObj)
    External (\_SB_.PCI0.GPP2.PTXH.RHUB.SS04, DeviceObj)
    // Define Rhub for Port injection
    External (\_SB_.PCI0.GPP2.PTXH.RHUB, DeviceObj)
    // Drop HS ports - Reboot after enabling for testing with IORegistryExplorer
    Scope (\_SB_.PCI0.GPP2.PTXH.RHUB.HS01)
        Name (_STA, Zero)
    Scope (\_SB_.PCI0.GPP2.PTXH.RHUB.HS06)
        Name (_STA, Zero)
    Scope (\_SB_.PCI0.GPP2.PTXH.RHUB.HS11)
        Name (_STA, Zero)
    Scope (\_SB_.PCI0.GPP2.PTXH.RHUB.HS12)
        Name (_STA, Zero)
    // Drop SS ports
    Scope (\_SB_.PCI0.GPP2.PTXH.RHUB.SS01)
        Name (_STA, Zero)
    Scope (\_SB_.PCI0.GPP2.PTXH.RHUB.SS02)
        Name (_STA, Zero)
    Scope (\_SB_.PCI0.GPP2.PTXH.RHUB.SS03)
        Name (_STA, Zero)
    Scope (\_SB_.PCI0.GPP2.PTXH.RHUB.SS04)
        Name (_STA, Zero)
    // Now that we have dropped these ports, let's add ports to RHUB
    Scope (\_SB_.PCI0.GPP2.PTXH.RHUB)
        // USB 3.1 Gen 2 - A connector
        Device (PT01)
            // Assign address 1 per the report run by USBDEVTREE in windows
            Name (_ADR, 0x1)
            // Package payload
            // 0xFF = Connectable
            // 0x03 = USB 3 Standard-A connector
            // Zero = Reserving for future use. Must be Zero
            // ^ https://uefi.org/sites/default/files/resources/ACPI_6_3_final_Jan30.pdf
            Name (_UPC, Package (0x04)
                0xFF,
                0x03,
                Zero,
                Zero
        Device (PT02)
            // Assign address 2 per the report run by USBDEVTREE in windows
            Name (_ADR, 0x2)
            // Package payload
            // 0x09 = Type C connector - USB2 and SS with Switch
                0xFF,
                0x09,
                Zero,
                Zero
        // USB 3.1 - Front panel, bottom
        Device (PT03)
            // Assign address 3 per the report run by USBDEVTREE in windows
            Name (_ADR, 0x3)
            // Package payload
                0xFF,
                0x03,
                Zero,
                Zero
        // USB 3.1 - Front panel, top
        Device (PT04)
            // Assign address 4 per the report run by USBDEVTREE in windows
            Name (_ADR, 0x4)
            // Package payload
                0xFF,
                0x03,
                Zero,
                Zero
        // USB 2.0 port on USB 3.1 Gen 2 - A connector
        Device (PT05)
            // Assign address 5 per the report run by USBDEVTREE in windows
            Name (_ADR, 0x5)
            // Package payload
            // Zero = USB 2 Standard-A connector
                0xFF,
                Zero,
                Zero,
                Zero
        Device (PT06)
            // Assign address 6 per the report run by USBDEVTREE in windows
            Name (_ADR, 0x6)
            // Package payload
            // 0x08 = Type C connector - USB2-only
                0xFF,
                0x08,
                Zero,
                Zero
        // USB 2.0 port - Front panel, bottom
        Device (PT07)
            // Assign address 7 per the report run by USBDEVTREE in windows
            Name (_ADR, 0x7)
            // Package payload
                0xFF,
                Zero,
                Zero,
                Zero
        // USB 2.0 port - Front panel, top
        Device (PT08)
            // Assign address 8 per the report run by USBDEVTREE in windows
            Name (_ADR, 0x8)
            // Package payload
                0xFF,
                Zero,
                Zero,
                Zero
        // Bluetooth internal
        Device (PT10)
            // Assign address 10 per the report run by USBDEVTREE in windows
            Name (_ADR, 0xA)
            // Package payload
            // 0xFF = Internal/Proprietary Connector
                0xFF,
                0xFF,
                Zero,
                Zero
        // USB 2 above PS2 port
        Device (PT11)
            // Assign address 11 per the report run by USBDEVTREE in windows
            Name (_ADR, 0xB)
            // Package payload
                0xFF,
                Zero,
                Zero,
                Zero
        // USB above PS2 port
        Device (PT14)
            // Assign address 14 per the report run by USBDEVTREE in windows
            Name (_ADR, 0xE)
            // Package payload
                0xFF,
                Zero,
                Zero,
                Zero
karistuck liked this
#53518
Could you share more about your configuration. I'm also using the ASRock B450 ITX and am having memory addressing issues.
When starting SSDTTime-master i've got no option t[…]
I tried to triple boot into Windows, Mac OS and Ma[…]
thank for sharing Post Merged having some trou[…]
Hey dude, Did you manage to install the Catalina?
