by: Johnata
#51080
Hi guys, now is my time.
My Hack finally working very well.
My geekbench
https://browser.geekbench.com/v5/cpu/95924
Configuration:
CPU: AMD Ryzen 5 2400G
Motherboard: GIGABYTE AB350-Gaming 3
RAM: Hyper 16GB 2400MHz DDR4
SSD: Samsung 970 EVO NVMe M.2 - 256 GB
GPU: NVidia GeForce 1060 6GB IGAMER OC 192BITS GDDR5
by: Doctor_VB
#51088
Hi @Johnata.
Do you have appropriate onboard audio working with your config? I have the same issue as described here, tried to use both AppleALC and VoodooHDA kexts, use busratio boot argument, USB sound card, but all without success: crackling sound. I thought that issue is related to Raven Ridge processors, but now you report about success with 2400G :thumbup:
Could you share your method to set up audio if it is working pretty good?
by: Johnata
#51097
Doctor_VB wrote:Hi @Johnata.
Hi @Doctor_VB
Did you change the frequency of your processor (CPU) for 3.60? Because the audio problem happing when you not change in BIOS the value of 3.59...
Did you maked that?
I changed my processor for that and now the audio working very well.
Hi, you can fix too buying a sound audiocontroller usb... I bought one simple and its work perfect now.
Like this: https://pt.aliexpress.com/item/33037497 ... b201603_53
by: Doctor_VB
#51226
Hi @Johnata,
Many thanks for reply. Sorry, today only could try your solution.
I've set the frequency in BIOS 3.60 - nothing changed.
Also I've tried to set CPU settings: boot argument "busratio=36", Frequency MHz 3600, Bus Speed KHz 100000. Nothing changed.
Maybe you can share your config.plist? I'd check your settings.
Virtualization on Ryzentosh
I just set up an AMD Hackintosh for the sole purpo[…]
Hello everyone, After the first pass of Catalina […]
Catalina Installer Screen Is Garbled
Yep. It definitely has something to do with the GP[…]
Oh dear! I don't have access to a mac... :cry: […]
