by: fabmacos
#50929
Hello everyone I would like to share my successful install on my risen 5 3600 build. All thanks to amd osx vanilla guide.
My build:
AMD Ryzen 5 3600
Asus Crosshair VI hero x370
G.skill flareX 32GB DDR4 3200mhz
SSD 512
MSI Vega 56
What I did was following the guide of the amd osx vanilla.
Everything works, iMessage, iCloud mail, App Store whit signing in with you're apple account. Internet and wifi works. Sound works and also jpeg preview
I also noticed that the windows key on you're qwerty keyboard is the CMD key on the Mac
Only I installed the ATI inject on the graphics page in clover boot menu.
by: jubarim
#50967
Hi! Nice build!
Were you able to make sleep work? Thanks!
by: fabmacos
#50973
Hi i still didn’t fix the sleep wake function! I’m trying do! If i fixed it i will make a tutorial for it.
My Mojave Hackintosh still works flawlessly. Even the sleep function is working great.
#52292
nice buid!
I follow you with C6H + ryzen 3600 and ram 32GB bus 3200. but i use ssd nvme samsung 970 plus
But I get "No Sign" screen every time when Boot by USB.
Can you share to me yourBios Setup?
Thanks for help!
Check my reply here out https://forum.amd-osx.co[…]
Check my reply under https://forum.amd-osx.com/v[…]
I’ve had that issue and it can be solved by […]
This method is not working on Ryzen 3700x after m[…]
