#50928
I'm very happy and proud to announce you that I succeded to make my hackintosh !
He's alive ! ALIIIIIVE !
I made a microATX hackintosh with a asrock X570M pro4 an excellent MOBO !
WHY ?
Because this motherboard is not very expensive, has very good VRM, 2 M.2 slot AND :
- a M.2 NGFF slot to put a wifi/BT ngff card ! (Yes dude !)
- a thunderbolt connector to put the thunderbolt AIC form asrock and add 2 thunderbolt 3 ports ! oh yeah !
And I took a Sapphire RX580 8gb nitro+, G.Skill trident Z RGB 3200Mhz CAS18 2x16Gb, a SF600 from Corsair, a DW1560.
What's working ?
For the moment everything is working !
Photoshop is working, illustrator, xcode, blender, sketch, youtube in 4K !
Maybe a little latency with the bluetooth but i can connect a magic mouse and magic keyboard without any problem !
the keyboard can't change the brightness of the screen and the sound ... but I think it's because my computer was plug to my TV
And I can't use a microphone (I don't know what to do ...)
for the DW1560, I'm using 3 kext brcmairportfixup, bluetoothinjector and brcmfirmwarerepo !
Have fun dudes !
Oz-man, TheRyzenGuy liked this
#50994
i tried 3 times and yes it works ;)
the 3600 is one of the most impressive CPU I have ever seen !
For about 200€ (and you can buy it for less than 200€ today), you have a CPU that crush a 9700K in applications !
And if you want something really powerful, you can take a 3700X and you have something better than the 9900K, I will buy this one or the new 3900 in 3-4 months.
And if you want a hackintosh equivalent to the most powerful imac pro, you take the 3900X (yes !)
I will put photos as soon as possible !
#51126
Need your help, please. I have same board, just not micro, I have full ATX, The X570 Pro4. It's identical though so your EFI & BIOS Settings would work with mine. I've tried & tried a fresh vanilla install with no luck. Please text me at 514-416-5160 or email me at [email protected] to help me, I will send you some crypto...you know...like Bitcoin? ANyway, please help! Thanks!
#51185
Not microphone...micro ATX...I had ASRock X570 Pro4 FULL ATX Mobo...You have ASRock X570m Pro4, "m" for "microATX" Doesn't matter now, I returned it & got a ASUS ROG B450-F Gaming. ASUS activated PCIe 4.0 on it's B450 & X470 Mobo's, so no reason to get X570 anymore. Update BIOS to run Ryzen 3700X & it activates PCIe 4.0 as well. I don't need SLI so X470 isn't important to me either. My ASUS ROG STRIX B450-F Gaming rocks the Ryzen 3700X with no issues, I can overclock the hell out of it, gREAT VRM...plus I have no issues with Ryzentosh, everything worked perfect first try AND I have PCIe 4.0 working on ALL PCIe x16 Slots & M.2 slots, not just the first one near top, ON ALL. So I don't need your help, thanks anyways.
#51191
manoueltiger wrote: Fri Aug 30, 2019 5:18 pm
Have fun dudes !
You saved me :) Thanks :thumbup:
#51232
@n8dagr8 : sorry mate, I didn't understand ;). Happy to see that you resolve your problem ;)
@ KojiAiba :
no problem, I had some issues with bluetooth because the firmware didn't update, so I put brcmairportfixup , firmwaredata, bluetoothinjectoor et patchRAM2 instead.
#51323
I have a similar Asrock x570 board (Taichi). Are you able to use iMessage? I followed the vanilla guide, and everything (except onboard Intel AX200 wifi, but that was expected) seems to be working - except iMessage. I'm getting activation errors. I have signed into iCloud and the App Store without an issue.
Did you do anything special with your Clover settings? I'm curious what your config.plist and kext settings are?
@gbp27 , Try with this.
Use a different USB port. It's hanging on Still W[…]
Using Hackintool for USB Mapping?
Is there a downside to using Hackintool for USB ma[…]
you think u can help me too with my USB map pls ? […]
