by: Rohank98
#50024
Thanks to this community and everyone who put in the work to make this possible I finally managed to get High Sierra up and running on my AMD PC
My current specs :
CPU: AMD FX 6300 Black Edition
Motherboard : Gigabyte GA-78lmt-USB3
GPU: Zotac GTX 1050ti 4GB EXOC
Memory: 8 GB DDR3
Storage : 250gb HDD for Mac
Dual Boot : Windows 10 on my SSD along with 1TB HDD
Mac Version : 10.13.3
Installer Used : AMDHS v3 Unofficial
Tutorial :
1.Follow the Install and Post install steps in this post : viewtopic.php?t=4127
2.Install Clover and don't make any changes in the customize installation section
3.Copy the entire Clover Folder from the USB installer and replace all the files in your Mac's EFI>Clover folder
4. Config file i used was the InjectNvidia.plist with minor changes, just rename it to config.plist and replace it with the original one
5.Kexts Used VoodooHDA latest one and Realtek RTL8111
Problems faced :
1.Multiple times my PC would get stuck in the bios Boot Loop and as a result I had to clear the CMOS , pretty sure i wasn't doing anything wrong but my pc wouldn't boot at all past the bios screen
2.Couldn't update to 10.13.6 , ran into a few errors here and there and finally I decided to stick to 10.13.3 because it ran flawlessly
3.My Motherboard runs on AWARD Bios and hence couldn't configure my clover installation well because there's not much information about it on the internet
Finally! What Works ?
For the most part it is a fully functional Mac installation
1.Ethernet and USB Dongle Lan with TP Link Adapter
2. Sound both Line Out and HDMI
3.Graphics Acceleration
4. Sleep and Wake
5.Every other basic function
What does not work:
iMessage and Facetime and other stuff like that which have very slim chances of it working.
Voice Input, but I'm yet to test it properly
Special Thanks to : Shaneee and the entire AMD OSX Community
Feel free to ask me questions if you need any help at all , I will try my best to guide you with your installation on a PC with similar specs .
#50457
I can't access the topic of permission error "You are not authorised to read this forum.", not only this topic but several others
ltz521666 liked this
#50491
我没有权限阅读本论坛。
Installed Operating Systems: Windows 10 64位 ( DirectX 12 )
CPU:AMD FX -6200 六核 Six-Core 4.10 GHz
Motherboard: 微星MSI 970A-G45 (MS-7693) ( AMD RD890 PCI to PCI bridge (external gfx0 port B) )
Graphics: AMD Radeon RX 570 ( 4 GB /Sapphire )
RAM : 8 GB ( 威刚ADATA DDR3 1600MHz )
SSD: 建兴liteonit CV6-CQ128 ( 128 GB / SSD )
安装的操作系统:Windows 10 64位(DirectX 12)
CPU:AMD FX -6200六核六核4.10 GHz
主板:微星MSI 970A-G45(MS-7693)(AMD RD890 PCI到PCI桥接器(外部gfx0端口B) )
图形:AMD Radeon RX 570(4 GB /蓝宝石)
RAM:8 GB(威刚ADATA DDR3 1600MHz)
SSD:建兴liteonit CV6-CQ128(128 GB / SSD)
HDD:1T 150G
#52997
Hello! I need a little help with my clover configuration it says: applealc neather alc-layout-id nor layout-id is found on configuration No HPETs available... CPU configuration incorrectly. Do you have any idea what it could be?
Does this work for Catalina 10.15.2 booting with O[…]
Sometimes there is the requirement to install the […]
How did you find us?
Snazzy Labs video.
I solve problem black screen with rx 5700 xt, addi[…]
