#49839
I have successfully installed HighSierra on this build, but with a little problem with DisplayPort and DVI, in fact i can only use one monitor with the hdmi (i have only 1 hdmi on the gpu)
CPU: AMD FX8320 OC 4.2Ghz
MOBO: Asus M5A97 R2.0
GPU: Gigabyte GTX1060 3GB
OS: High Sierra 10.13.6 (17G65) - VANILLA
EDIT:
I have fixed the issue with the monitors enabling CSM on bios. Now it's working fine
Having the same issue. Built this hackintosh speci[…]
Thanks so much for the response. I think I will […]
I have the same problem, when i boot from the USB […]
Hi everyone, i have successfully completed my Cata[…]
