#49560
Had to just use the config.plist from:
https://github.com/AMD-OSX/AMD_Vanilla/tree/master/17h
Had to reboot into the UEFI "Install" partitions twice to get the 1.14.5 install to work, was tricky due to motherboard kept changing the default boot from my UEFI clover install to my linux partition.
Needed to re-apply busratio=32 to improve performance (also changed "about this mac" from 3.19 Ghz to 3.2 ghz.
Still need to re-apply About This Mac tweaks, and confirm ram is running at 3200 mhz not 2400 mhz, but booting worked.
Shaneee's AMD Build
@Shanee Could you please share me your clover conf[…]
audio stuttering issue
Ryzen 2700x MSI B450m mortar Asus R580 Audio wor[…]
Unable to set Clover Theme
Thanks for replying XLNC :thumbup: I'm familiar […]
I now notice this statement at the NoVPAJpeg repos[…]
