by: StanRyzen7
#48058
Hey guys:
I'm new to the community so I apologize in advance for my poor understanding of the culture. I just completed my new build and I was able to get Mojave installed on my PC but I have no Wi-Fi or Bluetooth at this point. I haven't fully inspected the system but I was able to get MS Office and SPSS installed so that's all I really need. If anyone has any tips/advice on getting the Wi-Fi to work or any general advice, I would greatly appreciate it. Thanks!
Stan
Hardware
CPU: Ryzen 7 2700 OC
SSD: 120GB Samsung EVO 840
RAM: 16GB Corsair Vengeance LPX 15-17-17-35
MOBO: MSI B450 Gaming Pro Carbon AC
Egress liked this
by: HarryKC
#48061
MacOS supports only certain BT and WiFi modules and the one on Your motherboard is probably not compatible. It has to be a Bradcom module.
Usually the suggested card is the TP-Link Archer T9E 802.11AC AC1900 or if You can open the WiFy & BT box on Your motherboard just the tiny module without the antennas and the PCI board.
Hope this helps.
by: moonman
#48078
StanRyzen7 wrote: Thu May 16, 2019 12:41 am Hey guys:
hackintosh/osx doesn't support the onboard wifi/bt, get a broadcom combo card like this https://www.aliexpress.com/item/Broadco ... 60002.html
by: StanRyzen7
#49976
Thanks! I thought i replied to this earlier, but I ordered it a few weeks ago and it should be here sometime next week. lol love hate relationship with AliExpress
by: czyjian
#51495
I have the same mother board to you. I tried all of the inject IDs for the newest AppleALC. But the back microphone Jack is not work. How did you get your microphone work? Can U share me your EFI?
Hey guys! I'm chiming in here because I'm having […]
do u have a efi folder u can upload please thank u
Successfully installed High Sierra using OpenCore.[…]
It doesn't matter which BL you use (I use OpenCo[…]
