#47979
update from 13.2 to 14.4
THREADRIPPER 1950x + gigabyte x399 aorus gaming 7
XFX AMD rx480 - 3monitor 4k 60hz,1080p 120hz, 1080p 60hz
GTX1060 - as a cuda accelerator(windows only)
samsung 950 512x2 raid 0 - windows
WD black nvme 256 - osx
previous post is here
viewtopic.php?f=35&t=3722&p=43917&hilit=dygkset#p36533
this time I just followed 'AMD OS X Vanilla' guide
https://vanilla.amd-osx.com
thanks to AlGrey
'kerner patch for zen' is super convenien..
and Native USB support by AlGrey
viewtopic.php?f=24&t=4986
FakeSmc.kext
AppleALC.kext
AtherosE2200Ethernet.kext
Lilu.kext
NullCPUPowerManagement.kext
VoodooTSCSyncAMD.kext
WhateverGreen.kext
working things...
this time all USB port work fine whiteout genericUSB3.0.kext so shutdown work fine also..
and surprisingly 's3 sleep' working properly :thumbup:
Despite using NullCPUPowerManagement.kext too
and onboard bluetooth(intel 8265 wifi+bluetooth module) also working... after firmware injected by windows driver
audio- alc 1220
ethernet- killer 2500
XFX RX 480
not working
onboard wifi(intel ac8265 -> no driver)
monitoring CPU clock
recognize amd raid volume ->no driver
gtx1060 -> no driver and... macOS does not support cuda any more
Hmm weird. I'm using the lastest 17h but my OpenCL[…]
Ok cool, and do I have to add the kext folder that[…]
It won't be stuck on pmtelemetry. You've posted th[…]
Installation
same here anyone got any ideas?
