#46163
Hello,what`s your audio cards model .I can not drive my ALC892 using ApppleALC.kext .i see u drive the audio card successfully.it seems it`s not the problem of kernel.could u tell me what u have done to drive the audio card in details thanks.
#46175
maidou8223 wrote:
Tue Mar 12, 2019 5:25 am
Hello,I follow this tutorial to install
viewtopic.php?f=24&t=6043&p=45449#p45449
and
@denijsonc,Look at the top
SETTING YOUR BUSRATIO AND CPU AND BUS SPEED IN CLOVER CONFIGURATOR
viewtopic.php?f=24&t=3440
First thanks your reply,but the native audio is still not working on ALC892. Although I tried these methods step by step . :(
Cloud you tell me what is your audio card model ,which kext you have used and the version of kext.That would be more useful for me to solve this problem.
#46200
@denijsonc,
denijsonc wrote:Hello,what`s your audio cards model .I can not drive my ALC892 using ApppleALC.kext .i see u drive the audio card successfully.it seems it`s not the problem of kernel.could u tell me what u have done to drive the audio card in details thanks.
#46238
Otisss wrote:
Thu Mar 14, 2019 10:44 am
You can install 10.14.1 made by shaneee. my ALC892 on MSI B450 mortar works great with it.
yeah,it wored well on mojave 10.14.1 for me too.But now i have upgraded 10.14.3 and it`s invalid.It`s looks like his ALC887 has worked on 10.14.3 but ALC892 didn`t
#46362
How did you get it to update to 10.14.3?
Hi guys. I'm new here and new in this hackintoshin[…]
Help make USB Installer
Yes, ViciBox v.6 and later 6/7/8 can be successful[…]
Use only the internal GPU of the CPU because you c[…]
I understand what you tell me though I wanted to a[…]
