#45490
Hello All,
The guide I followed to the core: viewtopic.php?t=5902
Big thanks to Shaneee on compiling all the bitter stuff and making it available and easy to understand and follow.
I got everything working. For Wifi, I have TP link TL-WN725N-V3 which works like a charm after installing the driver from the tp link website.
Two things I would like to get done:
1. Be able to boot into the Hard drive without the use of USB drive, a step by step guide will be appreciated.
2. to be able to use iMessage and FaceTime.
1 thing I just noticed is the Apple store is giving me error on all downloads: "An error occurred during purchase. The operation couldn’t be completed. (com.apple.commerce.client error 500.)"
-abheedevta
I got to get the boot into hard drive by pasting clover EFI into the windows EFI.
Made the changes with clover configurator to get the Facetime and iMessages working.
Mac Store error got fixed by cleaning crls folder by following this video: https://www.youtube.com/watch?v=-bsRcYicD3Y
#48454
Teague wrote:
Mon Mar 04, 2019 3:12 am
definitely a fix for iMessage would be appreciated.
Hi, I fixed mine as below:
1. BSD Device Names
If the BSD Device Names of your Active Services such as Ethernet, Wi-Fi are set incorrectly this can prevent iMessage/iCloud/FaceTime from working.
Set correct BSD name:
Open Terminal
Paste sudo rm -rf /Library/Preferences/SystemConfiguration/NetworkInterfaces.plist into Terminal and enter password on prompt
Paste sudo rm -rf /Library/Preferences/SystemConfiguration/preferences.plist into Terminal
Reboot Hackintosh and check iMessage/iCloud/Facetime
Reset Mac BSD values
2. Bad System Preferences
If you have had Mac OS running for awhile then it’s a possibility that from mix matching things trying to get these services to work that the configuration files that these services use have gotten messed up. So what we can do is clean up these configuration files, but before you can do this step you will need to make sure you are signed out of all iCloud related services and restart your machine that way they aren’t running when we remove the configuration files they rely on.
To delete/reset Preferences:
Make sure you are signed out of all services and restart before beginning these steps.
Open Terminal
Enter sudo rm into Terminal to trigger password prompt if necessary.
Paste all at once into Terminal:
sudo rm -rf ~/Library/Caches/com.apple.iCloudHelper* \
~/Library/Caches/com.apple.Messages* \
~/Library/Caches/com.apple.imfoundation.IMRemoteURLConnectionAgent* \
~/Library/Preferences/com.apple.iChat* \
~/Library/Preferences/com.apple.icloud* \
~/Library/Preferences/com.apple.imagent* \
~/Library/Preferences/com.apple.imessage* \
~/Library/Preferences/com.apple.imservice* \
~/Library/Preferences/com.apple.ids.service* \
~/Library/Preferences/com.apple.madrid.plist* \
~/Library/Preferences/com.apple.imessage.bag.plist* \
~/Library/Preferences/com.apple.identityserviced* \
~/Library/Preferences/com.apple.security* \
~/Library/Messages
Reset Apple Services in Terminal
3. NVRAM for Activation
Depending on your hackintosh configuration you may need EmuVariableUefi-64.efi for activation. Unusually if its an NVRAM related problem you also shouldnt’ be able to log in to the App Store with your Apple ID in addition to iMessage/iCloud/FaceTime
To add EmuVariableUefi-64.efi:
Open Clover Configurator
Mount your EFI Partition
Open config.plist using Clover Configurator
Click Install Drivers on left column of Clover Configurator
Click EmuVariableUefi in bottom left box.
Verify EmuVariableUefi-64.efi exists in /Volumes/EFI/EFI/Clover/Drivers64UEFI/
4. Proper SMBIOS Settings for Working Hackintosh iMessage
If iMessage still isn’t working after resetting the network and deleting system preferences than it’s most likely issue with whatever values are set in the SMBIOS section of your config.plist. Problems with the way the SMBIOS is set is the #1 reason a lot of people aren’t able to get iMessage or iCloud working.
4.1 Generate an Invalid Serial Number
Download Clover Configurator if you don’t already have it
Mount EFI partition
Navigate to /Volumes/EFI/EFI/Clover/
Right-click config.plist and open with Clover Configurator
Click SMBIOS on left side
Copy the Serial Number
Go to checkcoverage.apple.com
Paste Serial Number and click Continue
If it comes back as valid you will need to generate a new serial number until you get a error or invalid serial number
Go back to Clover Configurator SMBIOS section
Repeat Generate New and paste to checkcoverage.apple.com until you get an Invalid Serial Number
4.2 Set Custom Board Serial Number
Now that you have your own invalid serial number you need to replace the Board Serial Number with one containing your Invalid Serial Number along with 5 random digits. Since they can be any digits I keep the last five digits of the Board Serial Number and replace the first 12 with the Serial Number
Copy Serial Number
Replace the first 12 digits of Board Serial Number with the copied Serial Number
4.3 Unique UUID
Open Terminal
Generate a unique string by entering uuidgen into Terminal
Copy & Paste the generated UUID value from Terminal into SmUUID in Clover Configurator -> SMBIOS
Save config.plist
Restart Hackintosh
Note: If generating your own SMBIOS values doesn’t work out for you then you can try using a valid Serial Number and verifying with checkcoverage.apple.com to find out if iMessage/iCloud/FaceTime issue is related to the SMBIOS or not. If iMessage works with a valid Serial Number then you didn’t generate your own SMBIOS values correctly. When using a Valid Serial Number you leave SmUUID blank. If iMessage/iCloud/FaceTime still doesn’t work with a valid Serial Number at least you know the issue is related to something else other than the SMBIOS values. If you can get your own fake Serial Number to work it’s recommended you not use a valid Serial Number permanently as that of course belongs to someone else’s Mac.
webdesz wrote:
Sun Feb 24, 2019 10:56 am
Does sleep work for you?
My Mojave 10.14.3 install (Ryzen 7, B-350, Radeon RX 570) sleeps well but after wakeup it works for 2 seconds and then crashes/freezes.
I did a normal upgrade and right now its 10.14.4. Sleep has worked with my system out of the box.
#49627
So How can I update from config.plist processor name? I am having unknown processor? Also, ram speed is incorrect.
1. BSD Device Names
Open Terminal
Open Terminal
~/Library/Messages
Mount EFI partition
Copy Serial Number
4.3 Unique UUID
Open Terminal
Save config.plist
Restart Hackintosh
Hello, How can I update unknown processor ? Also, memory speed is incorrect. Thanks.
Install hackintool and click bootloader tab, selec[…]
External Drive Patch for Ryzen 3000?
Ok, so I'm relatively new to AMD. I'm looking arou[…]
Yeah exactly... I think it's really important for […]
Hey Guys, I followed this guide (https://forum.am[…]
