#45448
I’ve followed shanee’s tutorial and installed high sierra 10.13.3 AMD V3.
Everything is great, the speed of the cpu is breathtaking, the installation was smooth and straightforward, except for one major issue, which is the GPU, it’s barely usable and it scores lower than 40 fps on Cinebench, to put that in perspective my old 950 GTX used to score above 70 fps.
I’ve tried many drivers and nothing worked for me. Unless I find a fix for it I’ll switch to the new amd radeon 7 gpu.
Wifi is working using TP-link card
External Bluetooth not working. *no internal Bluetooth on X399 ASUS Prime A
Sound worked immediately though the volume is noticeably low at maximum levels
just had a popup stating that update 10.13.6 is re[…]
VMware and Mojave?
HI is it possible to run macOS mojave in VMware on[…]
Please Help
In your clover config.plist you'll want to add a[…]
First of all I wanted to say thank you for the gu[…]
