by: Peter Luzsanyi
#45137
Dear Guys,
Mostly Happy. Fluent MACOS working, without any major issue. Great performance.
I am just follow this :
viewtopic.php?f=24&t=5902 THANKS TO Shaneee :thumbup:
MOBO : Asus Zenith Extreme, VGA: AMD RX580 8gb (ASUS ROG series)
Not working yet :
- WIFI
- HDMI audio
I cant spend too much time on it, so hoping these will work soon.
#45154
Add the attached HDMIAudio.kext file to your EFI > EFI > CLOVER > kexts > Other folder for HDMI Audio.
As for Wifi, what's the chip it uses? If it's built in there's a chance it won't work.
Can you upload your Clover EFI folder with kexts a[…]
hello everyone, I'm about to buy this motherboard:[…]
i have almost same pc. except gpu. i have rx 460.[…]
As the subject shows, i want to get some games fro[…]
