by: lukasb318
#45115
Successfully installed Mojave on my PC today. Just working on getting on board audio to work, however everything else is working perfectly fine. (If anyone has a suggestion to get this to work that'd be great.)
Thanks to Shane and everyone else that made the guides and Kernels.
Edit. With APPLEHDA.kext my on board sound works no issues.
So everything works as well as it did on my i7 build a month ago. But faster because more cores. :)
Shaneee, datdude717 liked this
#51277
How do you get audio working? Which clover patches / injects do you use?
APPLEHDA.kext it's a vanilla osx kext, yes? Do you use AppleALC.kext?
I'm using the same MB For the network i'm using […]
Hi all! I'm trying to install Catalina 10.15.3 but[…]
So quick update. I swapped out the WiFi card on […]
Recently, I need to use video camera a lot to in o[…]
