by: mrfundaynite
#44933
Just wanted to thank you guys at AMD-OS X for all of your hard work, research and dedication to helping others. I successfully finished a multiboot system Hackintosh system built into a Modified 2006 PowerMac G5 case w/ Windows 7, 10, MacOS SierraAMD, and Linux KXStudio. Specs are in my signature. Sierra runs fairly quick and smooth. As does everything else. I really appreciate everything you guys have going on here. Would not have been able to do this with out the guides and downloads you guys offer. Like the home page says "Don't Switch, Modify", I couldn't agree more.
Thanks again....
Can you help me? In my installation it gives sti[…]
How to force install 10.14.1?
The Vanilla patch made updating so easy. No more r[…]
The guide worked perfectly for me. Thanks. Specs[…]
try this https://www.youtube.com/watch?v=Y9I-OINW[…]
