#44754
My hardware detail:
1.CPU: AMD Ryzen 2700x
2. RAM: 32G 2400Mhz
3.MOBO: MSI B450m mortar
4.SSD: MX500 500GB
5.GRAPH: GIGABYTE GTX1070 G1 8G
6.CASE: INWIN 301
steps:
1.following the tutorial to install 10.13.3 unofficial
2.install clover r4813 to disk (this version is good)
3.install Nvidia web driver
4.install native usb fix
5.install native audio fix
6.replace new 10.13.3 kernel (It is on tutorial author's Github. after replace is become more stable)
I didn't test a lot of stuff
works:
1.HDMI (My display is Dell U2414H, the system can recognize it)
2.All USB (front and back, the speed is not as good as in windows 10. just about 80%) and Audio
3.Ethernet (speed is fine)
4.App Store, iTunes (works great with my super old iPhone), Pages, Photos (import photos from iPhone works great), Xcode (compile speed is super fast, iPhone simulator works great), Spotify, Shadowsocks
5.display sleep
not works:
1. power sleep
2. SSD TRIM
3. vm fusion
4. Wolfram mathematics
5. HEVC and H264 accelerate
tips:
if you just want to learn macOS relate development is ok to do this, but before replace new kernel , my cpu fan's RGB suddenly doesn't work during I restart the computer. so if you notice the hardware doesn't work like it suppose to, you should replace new kernel or just switch back to windows 10 or ubuntu. because hackintosh looks like will damage your hardware.
test score picture is in attachment
Can I get a hint as to how you got audio working? […]
Total AMD n00b - Vanilla Clover Patches?
Hey, do you remember how you went around to fixing[…]
Today I got my LAN kexts to work so I thought I'll[…]
Hey Guys, I am having this same problem. TransMac[…]
