#5496
  • CPU: AMD Ryzen 5 2400G
  • Motherboard: GIGABYTE AB350-Gaming 3
  • RAM: Corsair Vengeance LPX 8GB 3000MHz DDR4
  • HDD: 500GB 960 EVO - Crucial MX500 250GB - 1 x 2TB Seagate - 1 x 640GB WDC - 1 x 500GB WDC
  • USB : 3.1
  • GPU: ASUS RX 560 ROG STRIX 4GB
  • LAN: Realtek RTL8111 ( RTL8111.kext )
  • Sound: HDMI / Motherboard ( AppleALC )
  • Sleep: Works
  • Monitor: 32" HD TV
  • Bootloader: Clover
  • Other: iCloud works OOB. Working Bluetooth.
  • Installation Method: Retail USB
  • Installed OS': High Sierra 10.14.1 - Windows 10 Pro - Few Test Installations
Geekbench CPU:
https://browser.geekbench.com/v4/cpu/11383191
Old FX Build
Spoiler:
  • CPU: AMD FX-4300
  • Motherboard: GIGABYTE 78LMT-USB (rev 6.0)
  • Chipset:-
    North Bridge:
    AMD 760G
    South Bridge: AMD SB710 (SuperVIAATA.kext)
  • RAM: 6GB
  • HDD: 1 x 2TB Seagate (Main Drive) 1 x 640GB WDC 2 x 500GB 1 x 320GB
  • USB : 2.0 / 3.0 ( Works with my USB Fix )
  • GPU: Gigabyte GeForce GT 710 2GB ( Works OOB with InjectNvidia )
  • WLAN: Atheros AR5B91 with PCI Adapter ( Works OOB )
  • Sound: HDMI ( VoodooHDA.kext )
  • Sleep: Works
  • Monitor: 32" HD TV ( Spoofed as Apple Thunderbolt Display )
  • Installed OS': High Sierra 10.13.2 - Windows 10 Pro Insider - Few Test Installations
Geekbench,
https://browser.geekbench.com/v4/cpu/4899493
GPU:
https://browser.geekbench.com/v4/compute/1389975
My Old System:
Spoiler:
Not the best build but it started life out as a Compaq OEM PC. It does the job :geek:
This same build has had every version of OS X since 10.6 installed on it :thumbup:
CPU: AMD Athlon II X2 215 @ 2.70GHz
Motherboard: Pegatron M2N68-LA
Chipset: NVIDIA GeForce 6150SE nForce 430 ( AppleNForceATA )
RAM: 6GB 1066 MHz
HDD: 1x 2TB Seagate 1x 640GB WDC 1x500GB WDC
USB : 2.0 All working front and rear with USBLegacyOff=Yes bootflag
GPU: PNY GeForce GT430 1GB ( Works OOB with GraphicsEnabler=Yes )
LAN: Realtek RTL8201N ( NForceLAN )
Sound: Realtek ALC662 ( Patched AppleHDA )
Sleep: Works ( Sort Of )
Bootloader: Enoch installed to ESP set to auto boot OS X
Other: iCloud on El Capitan works OOB. Working Bluetooth.
Installed OS': El Capitan 10.11.6 - Snow Leopard 10.6.8 - Windows 10 Pro Insider
Any questions feel free to ask.
Edit: Here are my Geekbench results :thumbup:
https://browser.geekbench.com/v4/cpu/1017170
GPU OpenCL:
https://browser.geekbench.com/v4/compute/221178
by: pepitillo
#8215
Hello Shane.
I'd like to ask you how did you do to have sleep working in your machine.
I have also a OEM PC very similar with yours (same chipset and processor) which works very well. I could sleep and wake with mavericks and with some kernels in yosemite, but with el capitan it sleeps but doesn't wake properly.
#8227
pepitillo wrote:Hello Shane.
I didn't do anything to get it sort of working. It only works for a small time. If the PC is left in sleep for a long period of time it doesn't wake.
by: Hoshi
#8928
Could you upload your Geekbench results again? OpenCL too. The best if it would be in 4 version.
by: nandy
#9326
:shock:
on an athalon?
#9338
Hoshi wrote:Could you upload your Geekbench results again? OpenCL too. The best if it would be in 4 version.
I will when I get a chance.
@nandy, Of course :thumbup:
by: Hoshi
#9707
I will just ask, you got very old computer. How it is using it? How is performance? I know you are developer, how it is to code under it? Do you play games? What do you do on it? Also do you maybe use virtualization (because I need alternative to virtualbox for my Athlon :P)?
#18042
It does what I need it to do :thumbup: I don't really play games on it but when I do it obviously doesn't run the newer ones. Everything else runs fine on Windows or OS X. PS, Cinema 4D, After Effects etc. I'll update the Geekbench results later tonight. Any Virtualization is done from VMWare Workstation on Windows and Parallels on OS X.
Edit: Geekbench results updated. Not these were done as the system is. Dropbox is still running in the background etc...
Edit: Info updated :geek:
by: sam298
#37214
Shaneee wrote:It does what I need it to do :thumbup: I don't really play games on it but when I do it obviously doesn't run the newer ones. Everything else runs fine on Windows or OS X. PS, Cinema 4D, After Effects etc. I'll update the Geekbench results later tonight. Any Virtualization is done from VMWare Workstation on Windows and Parallels on OS X.
Hi Shaneee, I have pretty much similar desktop as yours - 78LMT rev 5.0 with GT 610. I am currently in sierra 5.2 - everything except usb 2.0 ports works but the screen freezes after few minutes of use. I am trying high sierra v3 now. I can't even boot past the verbose screen. I swapped to usb 3.0 port, and tried other usb ports but stuck at waiting for root device and screen glitches and freezes. What options did you use in clover to boot? Thanks
Hello=)
I also have the same problem. Ryzen 2600 MSI B450M[…]
Finally, installed High Sierra but i don't know if[…]
So I installed High Sierra on a second partition o[…]
Hey Guys, I followed this guide (https://forum.am[…]
