#38482
-Bios
Disabled Serial Port
No other changes needed
-Install Image
AMDHS_Installer v2 CLOVER EDITION (viewtopic.php?f=23&t=2948&sid=c70c83cc3 ... e9400c41a3)
Installed with out problem. Post install used scripts on installer. Installed and removed everything script asked. (Pressed and hold Y button :thumbup: )Boot loader used post install script to install clover. Didn't work first try. I copied installer EFS folder content to Mac osx EFS folder. That fixed boot hang. Using Clover Configurator configured to my liking. Bcuz windows already installed cant et clover to boot windows. But i am using different ssd any way. Can change to windows by pressing F11 and choosing other drive. https://www.tonymacx86.com/nvidia-drivers/ used for graphic driver. Everything works. Sound, gigabit internet, gpu driver. This was my first try. I dont know i missed something or done wrong. But maybe helps some one with same specs.
English not my first language show mercy pls :roll:
kisucha liked this
Magna RX Weak nerves interfere with man's Magna RX[…]
Screenshot at Feb 21 15-38-21.png CPU : AMD […]
hello, i am new to the forum can anybody please pr[…]
Hello, I am new to this hackintosh and i've been w[…]
