by: lucasbesen
#37547
Configs:
AMD FX 8350
ASUS M5A78L - LE
8GB DDR3
NVIDIA GEFORCE GT 630
I would like to thank you very much, @Norton287, for all the support. I'm sorry for making you lose a couple hours of your days. Thank you, again.
AlGrey, vicgregor liked this
by: SimpleDino
#37889
What guide did you follow? And any other tweaks?
Br
Skickat från min iPhone med Tapatalk
by: vicgregor
#37900
SimpleDino wrote:
Sun Feb 18, 2018 11:35 am
Br
There is a guide for SierraAMD v4 that still works today although the file path for post.sh is slightly different (but you can always use the first character+tab trick to do the job for you).
It didn't get OS X to work perfectly right away, so also get ready for some adjustments on Clover with Clover Configurator to make it work properly and do some searching through here to find some information if you don't want to use Enoch (it's less flexible than Clover, I use it and I needed to figure out many things manually, but now my system is perfectly settled). And also a Mac-friendly graphics card (Radeon RX or Nvidia GeForce 900-1000 are your safest bets).
Doesn't work.. I added my config.plist to pastebin[…]
Hey guys ! I updated from High Sierra (10.13.6) to[…]
Having same issue with my build
After I update to high sierra 10.13.6 i install […]
