by: 4ilo
#37343
After struggling for 2 days trying to install the latest HighSierraAmd v3.0 and v2.0 without success.
I tried installing SierraAmd v5.2 with the clover bootloader and success!
Machine:
- Ryzen 5-1600 @ 4.0Ghz
- Msi B350 pc mate
- 16Gb HyperX 2666Mhz DDR4
- Nvidia GT520
Drivers:
- With Kext Utility i installed the RTL8111 ethernet drivers.
- Used http://www.insanelymac.com/forum/files/ ... a-patcher/ to fix the audio
- Installed NvidiaWebDrivers for my version
The only thing is i have some strange behaviour with my mouse pointer where the state sometimes doesn't change correctly.
I am very happy with the stable result.
Following https://forum.amd-osx.com/viewtopic.php?[…]
@Valamyr @Marcyvee It's working on Mojave when &q[…]
hello shanee I am stuck at the first start on the […]
zederex Clearly, this is going to lengthen the[…]
