#24256
Shaneee wrote:
Wed Jul 26, 2017 6:34 pm
@jaker89, Install the latest Enoch from the link below and copy the Extra folder from the post install folder to the root of your HDD. What's your GPU?
thanks for all the help and sorry for not following the forum rules, Ive done everything as the tutorials pointed
my specs
FX8300 8core 3.3GHZ
16GB RAM 1600Mhz
GTX1050Ti
Msi 760gm p23 Mobo
about the booing I will try again but what about the missing icons? they are just green bars
Thanks again guys
#24258
That's because there's no GPU acceleration. You need to install the Nvidia Web Drivers and enable them :thumbup: See here, viewtopic.php?f=24&t=1702
#24296
Dundas1728 wrote:
Wed Jul 05, 2017 6:28 pm
Sierra AMD v4, worked out of the box, just followed the Post Installation text file and voila!
The process was easy as any other hackintosh methods (Intel) and almost like installing the thing on a real Mac.
Ethernet working
WiFi Working
Sound Working
Sleep/Wake no working but as I read in other post its either work or not.
FX graphic glitch resolved after enabling GPU.
Did a couple of tests, Logic Pro X, Final Cut and Xcode , AMD beats my iMac 2013 (intel core i5 2.7ghz)
Thank you very much Shanee I will gladly contribute to this amazing project ! :thumbup: :D :) :clap:
Hi, I've installed Sierra AMD V4 on my AMD FX6300 system too. But It has some minor performance mistakes. Can you tell me, what system definition did you select and what is your bootflag about your graphics card? Mines are iMac 14,2 and GraphicsEnabler=Yes.
You said "after enabling gpu" How did you do that? Thanks.
by: John kfk
#37226
I need help to install mac osx seirra on my and fx 6350 on version 5.0.0 please help me
Hey guys, I built my first Hackintosh thanks to yo[…]
i want to buy a Intel based laptop with 16GB memor[…]
So I was able to finally find an All-in-one packag[…]
So I managed to get it to the first screen after h[…]
AMD OS X Advertisements
