by: lermitlodeiro
#55953
In order not to break the quietness and seriousness due to pesky mobile rings, cell phones are prohibited from using in many places like the meeting room, tribunal, and classroom and so on. What's more, cell phones are strictly prohibited in those confidential places to avoid the leak of the confidentiality. And you cannot let everybody keep their mobile phones off. Here, cellphone signal jammer can help you. With it, you can solve this problem easily.
@JerukLemon , note that only rev 1.1 supports TB […]
Ryzen 3900x 32 bit apps
Install a high sierra, you can run 32bit on that. […]
Drive is locked
Latest Firmware already installed on the drive. W[…]
No need to start from scratch. Make sure you updat[…]
