Have you found a bug with the forum or just want to give feedback on the site? This is the place.
by: CoiledViper
#45385
Okay. After Installing Mountain Lion AMD and putting on the necessary post install scripts on the terminal and restarting it. I cannot boot from my HDD. After Boot macOS from MountainLionAMD the next choice is Start UEFI 64. What should I do now?
How to force install 10.14.1?
The Vanilla patch made updating so easy. No more r[…]
The guide worked perfectly for me. Thanks. Specs[…]
try this https://www.youtube.com/watch?v=Y9I-OINW[…]
I have same cpu, any tips appreciated. Firm inte[…]
