Have you found a bug with the forum or just want to give feedback on the site? This is the place.
#44439
Hi,
A problem I had with many tries to setup more Mac versions is this one:
When you have to choose on which drive you want the system being installed,
the HDD that I've totally cleaned for the installation doesn't show up in disk utilities.
I already tried to make the hard drive ready for the Mac OS by using Transmac with
it's function "format disk for Mac" but that didn't help either.
Maybe I have to use a particular boot flag?
Anyone who knows a solution for this problem?
Thanks in advance for any reaction!!
84 views.... I hoped to have gotten some answer here...
Maybe my question is too stupid or trivial that nobody takes the time to answer?
Or, on the contrary, maybe it's that rare or difficult nobody can answer it?
Or has this problem never occured with any of you?
How to force install 10.14.1?
The Vanilla patch made updating so easy. No more r[…]
The guide worked perfectly for me. Thanks. Specs[…]
try this https://www.youtube.com/watch?v=Y9I-OINW[…]
I have same cpu, any tips appreciated. Firm inte[…]
